OctaneRender™ for Blender 1.30 - 3.2 beta Win [OBSOLETE]
ROUBAL
Yes, and I found nothing about Octane version used by the plugin in the Documentation got through the Button in the Render:Octanerender Engine (v.1.30 - 3.2 beta) Addon panel.
The System panel allows to enable GPUs to be used, but no path for the Octane version.
JimStar
Octane engine version is the first block of plugin version number. In this case: 1.30 - 3.2. Blender version number contains the Blender version in parentheses (in this case 2.69).
You don't need to have the same version of standalone installed to run any version of plugin.
ROUBAL wrote:... I found nothing about Octane version used by the plugin...
So, you have found it, you just have not seen it.:mrgreen:
ROUBAL
Thank you very much ! I hadn't understood that the render was Inside the plugin or server ! I thought it had to call an already installed version ! Thanks a lot ! :)
Saramary
JimStar wrote:Octane engine version is the first block of plugin version number. In this case: 1.30 - 3.2.
The same I've meant.)
Win 8.1 x64, i7-4930K 64GB, 2 x GTX-690
dafassi
JimStar wrote:dafassi
I can't reproduce.
Can you give me the scene?..
Im sorry- that would be an unsimulated file where you would have to simulate by your self the 400res fluid simulation with float-particle.
BUT- i found out that the issue is not specialy one of octane - its something inside blender.
So- for everyone who has the self F12-Crash-Problem: Just set the render-display to "Image Editor" and everything works fine.
Set to "New window" seems to be a problem in some scenes- but as i can read im not the only one with this problem!
Greets!
WIN7 64bit • 32GB DDR5 RAM • Intel i7 6x4GHz • GeForce GTX780 • Blender
kavorka
What was the particle instancing bug that was fixed?
JimStar
kavorka wrote:What was the particle instancing bug that was fixed?
"Scatter" mesh instances did not render in previous version...
kubicki3d
Hi
I'm having a problem with rotating an hdri texture. It seems that X and Y inputs have no influence on the rotation during live viewport rendering, no matter if I'm using Octane Rotate Transform or Octane Full Transform. Am I missing something?
Thanks in advance, cheers.
EDIT: OK, now I know, I should have used Translation instead of Rotation. Sorry for that.
i7 5960X | 64GB RAM | Win10 Pro | ASUS X99 Pro mobo | Chieftec 1250W psu
MSI GTX 780 Ti OC 3GB | 2 x GIGABYTE GTX 780 OC 3GB on USB risers | MSI GTX 750 Ti for display
Blender + Octane | C4D + Corona
Flickr profile: http://www.flickr.com/photos/kubicki3d
MattRM
Just one question, in Octane 1.30, an option is great but I don't find it in Blender Octane, it's the Object layer map. Did you already put it in the plugins or not ?
Also I found the plugins a few (like 25 %) less faster than the standalone.
In all way, the plugins rocks !!!
Matt
kubicki3d
Hi
I've noticed a strange behavior during rendering on two gpus. The final image is way darker than what I get in live viewport and has an alpha channel applied all over it (about 70% opacity). It's only like this when I'm using both of my gpus - with just one gpu ticked everything's fine. The problem did not disappear after reinstalling Blender / Octane Server. I've switched back to 2.68 / 1.20.2 and everything works ok. It might be worth checking out.
Cheers
Szymon
Return to “Blender”
