IMPORTANT
- if you like to keep both, old and new plugin versions, pls refer to this post: http://render.otoy.com/forum/viewtopic. ... 69#p170169
- this version keeps all settings and resources in a single location, in particular this is C:\Users\YourUsername\OctaneRender - there you'll find a (new) \Data folder, containing the plugin settings file, the Live DB cache database and the user preset database. also map resources (like Octane HDRI maps and IES files as well as some icons) are now located there in new subfolders).
- as the settings location (and structure) did change, you will need to enter your plugin license username/pwd once after the installation, just like when installing initially; the activation will come up right after the installer is closed; if you are unsure what to put where, pls refer to this post: http://render.otoy.com/forum/viewtopic.php?f=44&t=29942
note: if you like to skip this step you may copy your current plugin settings file into a new location; from here:
C:\Users\YourUserName\AppData\Roaming\DAZ 3D\OctaneRender_settings.oczdb to there:
C:\Users\YourUserName\OctaneRender\Data\OctaneRender_settings.oczdb
before running the installer... the "\Data" folder needs to be created anew then. - this version uses a new format for the Live DB cache, means the cache will need to be filled up again. if you have a fast internet connection and like to fill it up all at once, you may do so by: open the Live DB entry in the Materials tab, click on any item in the Live DB materials list, do CTRL-A to select all and CTRL-SHIFT-M to copy them all into the current scene; this will download all thumbnails and settings into the cache.
- this version has a completely redone save format, it will currently not load octane scene settings from old DAZ scene files; an update which allows to migrate old scene data into the new format will get available as soon the new format is proven to be bug free.
- during the next days i'm going to post a couple of additional posts to this thread, to describe all the changes and new features...
- please refer to this post: http://render.otoy.com/forum/viewtopic.php?f=44&t=30137
