procedural texture
ArminBeier
Hi
Is it possible to parent the procedural texture like checks, marble, turbulence to the object I assigned it?
Because when I animate the object with this material settings, it just looks weird. It stays at it's place while the object is moving.
Or can I bake the currect seen setting into a texture map so I can animate it?
examples of what I mean:
OS: Win7 x64
CPU: i7-4770 @3,40GHz
Mainboard: Z87-Deluxe
GPU: 2x GTX980 Ti Hybrid
RAM: 32GB
HD: 250GB SSD
Hi
Set the "projection" pin on the procedural texture to "UV".
ArminBeier
face_off wrote:Hi
Sorry, but I don't know where this projection pin should be.
Searched in the online manual, but didn't found anything.
I am using the plugin 1.20.2.1
OS: Win7 x64
RAM: 32GB
HD: 250GB SSD
The projection pin is a feature of the latest TEST version of the plugin. You will need to use it to do what you are trying to do.
ArminBeier
OS: Win7 x64
RAM: 32GB
HD: 250GB SSD
Return to “Poser”
