When you load a background image, is there a way to save it as part of the rendered scene?
Background Image
And use photoshop to remove white noise around the edges... though it doesn't do as goo of a job I think as Poser for rendering the alpha channel.
RAM: 64GB
OCTANE PLUGIN VERSION: 2025.6.0.4.5 Prime
DAZ STUDIO VERSION: 4.24 Pro Edition (64 bit)
RAM: 64GB
The actual saving of the Octane Viewport is done by Octane itself - and it doesn't know about the background image (that's something the plugin handles) - so you need to compose in PS. Sorry.Kinda what I thought. I was just thinking if I'm going to use PS to merge anyway, why not just save it from Octane. Or a prompt to save the background with the render or not
Ya know... all in all... except for alpha channel... it's a bloody good Poser renderer....
RAM: 64GB
RAM: 64GB
If you REALLY would like to do everything in one application you'd still have the possibility to take the one-sided square primitive from Poser assign the picture to it in the material room, set it to diffuse and render it out in Octane.
I did it this way before and it worked just fine!
You can still keep the "alphachannel" enabled but also enable "keep background" so he's going to render the background image anyways BUT with the possibility of removing it later in PS.
W10 64 bit | i7 3770K | MSI Geforce RTX 2080 (8GB) + GTX Titan Black (6GB) | 32 GB DDR3 RAM
