Moi3D to Octane is working correctly
Sam
When exporting .obj from Moi3D
Materials are OK
Object names are OK
NGONS / QUADS / TRIS are OK
Everything work :)
http://Kuto.ch - Samuel Zeller - Freelance 3D Generalist and Graphic designer from Switzerland
radiance
yeah the OBJ importer can parse/use NGONS. :)
Radiance
Sam
That's quite amazing :)
(because some expensive programs cant :lol:)
candide
When I export a simple cylinder from MoI with the highest amount of polygons (exporting ngons), I get rendering artifacts like this. What might be the cause of it? The problem goes away if I export at lower resolutions.
Ich bin ein Octaner -- XP 32bit | Geforce 9800GT 1GB | Core2Duo 2.4GHz | 3GB RAM
Sam
Smooth error or invert normals ;)
Try output in triangles from MoI 3D
candide
That helped. Ok so the best workflow MoI -> Octane is exporting triangles?
radiance
octane converts everything it reads to triangles during import,
so it does'nt matter if you use triangles or not. :)
once octane has loaded the mesh, it keeps it as triangles in memory.
Radiance
Sam
Yes but I have some ngons mesh from MoI3D that Octane fail to convert to triangles and make very ugly results :lol:
But its maybe MoI3D fault, I don't know.
