Hello guys,
I'm playing with Octane for some days now and I need to be highlighted on the linear workflow.
I have read some informations on the forum, but I'm still confused about the correct settings for 3ds max.
I was a Vray user, so I used the settings you can see in the attached files.
(When I need to send a JPG, BMP or PNG, I set up the output gamma of max at 2,2. When I need an .EXR or HDR, I set it up at 1.)
So my questions are (in the case I want a jpg output) :
- Do I leave the 3ds Max settings like these I'm using on vray ?
- In the camera "Imager" do I need to raise the gamma from 1 to 2,2 ?
- In the RGB Image in the material editor, do I need to raise also the gamma from 1 to 2,2 ? (if I use a jpg/PNG)
Thank you in advance for your answers, and sorry for my engilsh !
Gamma 2.2
AMD 9950x3D / RTX 4090 / RTX 3090 / 192 Go DDR5 / Win 11
http://www.remy-kerbiquet.com
umm.. this is how I started using it lately.. disable 3d max gamma correction (or it will add to octane ones after you "port to max framebuffer" , switch to 2.2 gamma in octane render settings, and to linear in response.. you get better shadows, increase exposure..
.. or maybe use the octane gamma 1.0 and then port to max framebuffer (I use the first technique anyway)
- other colour respones generate some gamma anyway, I am still on a lookout gamma workflows / the theory should be - if you're going to work on this footage in post pro, keep it in 1.0 .. well..
3dmax, zbrush, UE
//Behance profile //BOONAR
There is a tutorial on this in the tutorial section..basically (if I understood correctly) octane is already setup for working in linear workflow...so u shouldnt have to tweak anything.
Can someone enlighten us on this?
Nildo
Nildo
Corei7, 6x GTX1070 (2 Inside and 4 in a CUBIX Xpander), 32GB Ram, Win10 64Bit Home, 3dsMax2017 64Bit, Octane for max 3 and LOVING IT!!!!
MSI GT72S 6QE Dominator Pro G win10Home, gtx 980m.
- gabrielefx
with Octane you have to enable gamma 2.2 in Max control panel
deactivate material gamma
activate color selector picker
If you don't turn on color selector gamma you will get a linear ramp
regards
regards
so gabrielefx, you say the octane have the correctly gamma in the setting ? becouse i have that doubt using octane for 3ds max
regards, thank you for reply
what happen with input an output gamma ? i men, in vray input 2.2, output 1.0m but max2014 don't have this option input outpout
how can i fix this part ?
So for correct linear workflow you have to disable Max gamma settings, set the gamma to 2.2 in the octane camera and switch to linear response?
Can anybody from otoy confirm this?
Octane for 3ds Max v2.21.1 | i7-5930K | 32GB | 1 x GTX Titan Z + 2 x GTX 980 Ti
