keep environment option is offLudovicRouy wrote:I will try with previous version but with this release i can't get HDRI background.
Did i make something wrong ?
New version 1.23.2 (SDK 1.37) *** 25.03.2014***
- LudovicRouy
- Contact:
Thanks, I've seen that option a little after my first post that why i've edited it (i've done many tries before post and forget to reactivate it).
As you can see even with this option it doesn't render the background, I've try to desactivate the openGl option for c4d workspace(ctrl+maj at c4d startup) but nothing better.
And i've tried to launch c4d on my two different GPU (onboard G41 and GTX 460) but results are always the same.
So I post the test here if it could help, and i'm gonna trie the stable version 1.01 to see if there is a difference.
Regards,
Ludovic.
Regards,
Ludovic.
- octane test.rar
- (114.19 KiB) Downloaded 241 times
- LudovicRouy
- Contact:
No error on 1.01, HDRI is visible so I'm gonna wait a stable version of new SDk...
- eyeonestudio
- Contact:
When Nodegraph Open... can't click or drag nodegraph window.
So... Click desktop & return c4d. now can click & drag nodegraph window.
(c4doctane 1.1 + R15 + Windows 8.1)
Can you submit camera-mapping sample scene?
C4D R2026 / Win11 / AMD TR WX Series / 256Gb RAM / RTX 5090 FE / 100GbE
yes, need a fix for that.eyeonestudio wrote:When Nodegraph Open... can't click or drag nodegraph window.
- cameramapping.rar
- (116.73 KiB) Downloaded 226 times
geo. updates was turned on? is it reproductable?jmarx wrote:I ran into a very strange issue last night. It seems that in 1.10 certain objects would refuse to render. It was almost as if they had Object ID tags with Camera visibility off, but none of them had tags at all.
can you give me a scene has problems? I'm working on updatesjmarx wrote:Yes, this seems to be reproducible problem in R15 1.10. I just tried it again to make sure, and same result. I can open the same scene in R14 1.07b and everything renders fine. Geo updates are on.
