OctaneRender™ for Blender 1.27 - 3.1 beta Win [OBSOLETE]
JimStar
OctaneRender™ for Blender plugin. Windows x64 version.
1. OctaneRender™ Server
The first part (server) should be run on the same computer as the second one. To stop the server - just right-click its icon in the tray.
This is the quick-fix release.
  • New Octane simple-value nodes (Float and Int) did not work properly when connected to pins, fixed.
  • Fixed material preview look.
  • Fixed "Cylindrical projection" spelling.:oops:
Blender Octane Edition - 1.27 - 3.1 beta (2.69) (53.5MB autoinstaller file)
Octane Server - 1.27 - 3.1 beta (7.7MB autoinstaller file)
orion_uk
Many thanks JimStar ;)
PS: Dont wirry aboot the spilling, I di it all the toom :lol: :lol: :lol:
:roll:
http://www.Neil-Isted.com
Intel i7 870/2.93 GHz
RAM 16GB
1x Titan (6GB)
2x GTX 660Ti 2GB
Win10 Pro 64-bit
Carrara 8.5 Pro
Carrara - OR4C
Ds pro
OR Standalone V4
Poser Plugin
afecelis
That was fast! Thanks a lot Jim, time to test. :D
Win10 Pro | Geforce GTX1070 8gb Vram X2 (display/render) | Intel Core I7 4770K 3.5GHz | 32GB DDR3 1600 Ram |Nvidia 378.78 drivers | Cuda 8.0 | Blender/Modo/Sketchup
Ide
World > HDR image texture settings.
I can't rotate the HDR image in World > Octane environment
Because there is no X or Y rotation settings for the texture
JimStar
Ide wrote:World > HDR image texture settings.
It's not the plugin's issue (not the issue at all).
Just check out how it now works in last versions of standalone...;)
Ide
Ok, sorry about that. Have to check it out. :)
Ok. I have tried the standalone octane render 1.28 and there is the Texture Environment > RGB Image (texture) changing the Transform Value (UV transform) > T.X value rotates the HDR image.
In blender Texture nodes there is a Transform node input in Octane Image Tex
how can I change the Transform value if there is no Octane Rotation Transform node in Texture nodes?
Is there a manual somewhere where I can study how it works? :?:
I don't know if this is the right place to ask about this. Maybe someone could point in the right direction. Thanks.
dafassi
Sorry i repeat:
As i told you i opened the Blender Octane Folder and started the blender.exe from there.
But still the normal blender will be loaded.
I DEINSTALLED my regular Blender 2.69 because i thought there could be a conflict.
But that didn´t solve the problem.
It looks like i have a normal blender.exe in my octane package :D ... how can that be (fixed)?
This means: I dont have any Octane Features in my Blender!
WIN7 64bit • 32GB DDR5 RAM • Intel i7 6x4GHz • GeForce GTX780 • Blender
Ide
@dafassi
Have you tried to activate the plugin from Blender user preference > Addons > render:OctaneRender Engine?
dafassi
ide ... thank you!
That was it ... i was wondering- in other updates i never had to enable it again.
Works now .. puhh :D
Force44
Thanks for the new plugin!
Jimstar i find in http://blenderartists.org/ the addon "IES Lamps to Cycles"
http://blenderartists.org/forum/showthr ... -to-Cycles
Maybe you can integrate the same "principle" to octane render plugin into blender ?
http://www.picfad.com
Core i7 2600k @4.2 Ghz | Asus Maxiumus V Extream | 3 x GTX 590 watercooled| Crucial Ballistic Sport 32gb | Crucial m4 64gb | Seasonic Gold 1250 | Octane render| Skethcup Pro 2013 | Blender 2.68
Return to “Blender”
