Couldn't wait till Tuesday Jessie
Loaded your scene with 5 titans
61.97 Ms/sec
Reached 4500 samples in 2:30 ish
Will play around with some liquid textures when I get a chance man
Peter
Real Flow Particles
- p3taoctane
- AquaGeneral
That is insanely fast!
I had made a few tests in Real Flow in getting a good looking, proper smooth mesh. I will have another try in getting a mesh for you.
GeForce GTX 980 + GeForce GTX 570 | Intel Core i7 2600K | 8GB of RAM
- AquaGeneral
I've got a fairly nice looking mesh now. You can have a look at it here: https://dl.dropboxusercontent.com/u/900 ... _00110.zip
Love the real world physics and super real rendering quality of this abstract subject.
One of the CGI animators UK based. This one at 3D Imaging producing character design 3D in style and architectural visualisation London work.
- AquaGeneral
Train smoke does sound like Arun exercise, though are you actually planning on using Real Flow to simulate the smoke?
- xxdanbrowne
I've only spent a couple hours playing with realflow but there appears to be something wierd about the alembic export: it seems to export a sequence of "mesh" files in alembic format instead of a single alembic scene with a single deforming mesh. Anyone know if that's the expected behaviour or am I just a bit slow?
I was attempting to recreate the stargate fwoosh where the event horizone swooshes like a giant bubbling teardrop before snapping back and settling into a pond like surface.
I basically poured a sphere shape through a hoop into a mould which I made in zbrush of the shape of the fwoosh and let it simulate forwards. I think it more or less worked but it will require a ton of post work to composite everything together if it's an object sequence I need to manually load and render individually then re-composite back into a clip. I was hoping I could get the deforming mesh as an alembic file. But I appear to be doing something wrong.
- AquaGeneral
The script in question was really a very hacky thing.. I unfortunately also don't have the scene anymore.sagun wrote:Is is possible to still get the script ? I think the dropbox link is not working. This would be amazing.
