New version 1.23.2 (SDK 1.37) *** 25.03.2014***
TBA3D_70 wrote:The new mac test plugin for version 1.27 produce a message at C4D startup (R15 newest).
--> "can´t load the octane plugin binary"
Best regards,
Thomas
hi,
you need to change the name from "octane-r15.dat" to "octane.dat" in maxon/r15/plugin/c4doctane.
ciao beppe
Sorry, it's my mistake. Corrected the names.
Thanks Beppe, is it working good?
TBA3D_70
Now, with the changes --> themes ok on mac OS X R15 :D
is it ok? i found some errors on sdk for 1.27. It gives cuda error on some render start, posibly it's related with Render Target.
jmarx
I'm running into an error where my maxsamples setting won't stay set when I switch between scenes, or when I close and reopen a scene. For me it always resets to a different value (in my case 1000)
blodge
jmarx wrote:I'm running into an error where my maxsamples setting won't stay set when I switch between scenes, or when I close and reopen a scene. For me it always resets to a different value (in my case 1000)
I'm also running into this problem. Seems like the kernel is setting itself back to some default value when switching scenes.
ok, thanks. i'll check it
SVITAdmin
Finally was able to test this version on our Macs and PC's. Both versions seem to be running well. I have not dug into it too far yet though
1 Dell Z840 with 2x Titan XP's
2 Digital Storm Hailstorm/Win8/32GB/EVGA Titan x4
2 Server blades with 4 Tesla K80's
SVITAdmin
After playing around on the Mac all day, seem to get random crashes for no reason. Can't reproduce it, it just happens. Last crash report attached.
_BugReport.zip
(31.53 KiB) Downloaded 257 times
LudovicRouy
I will try with previous version but with this release i can't get HDRI background.
Did i make something wrong ?
