Hello,
I have a small activation problem on my machine...
I used Octane about 1 hour ago and after the rendering i closed my PC. I had to make a new rendering now and i powered on again my computer. In the mean time i changed the location of the Broadband (mobile sim) connection from a USB port to another USB port. But the Octane is now asking for a new authentication. Attached is a screenshot.
I had to go to octane live account on the website and to deactivate my license. And after i waited about 10 minutes the program could start.
A few weeks ago i changed the primary GPU from BIOS and i got the same problem.
This is a drawback ...
Marius.
the Live Account is buggy and causes problems
- mib2berlin
Hi, this is a security system of Octane, not a bug.
If you change any hardware setup Octane think you are on a different PC.
Cheers, mib.
Cheers, mib.
GTX 760 4 GB Driver: 430.31
Octane 3.08 Blender Octane
- UnCommonGrafx
What you have described is a 'bug' in process, not Live Account.
Read above.
Read above.
i7-4770K, 32gb ram, windows 8.1, GTX Titan and gt 620 for display
I know that is a security feature, but it seams kind of silly from this "feature" to ask me to authenticate again if i change the location of the mobile Internet connection from a usb port to another.
In case you did not understood ... the same machine, the same gpu, the same web connection, only the usb port was different. I changed that port when the PC was off. And it asked me to authenticate even before the connection was established (this means that the internet conn. was off). And as i know, if you're having a activated license and you're not having a active connection, the software still works.
And if i go by the "change any hardware setup" logic ... this means that if i'll add a new usb device, or ram stick, or another gpu, i have the re-authenticate? Not good.
In my opinion the license is tied to the PC until i'll release it from the live account menu in the Octane website.
And by the way ... i am currently using the license on 2 machines - work and home, so i deactivated / activated for about 100 times until now.
I do not need an answer/solution to my "problem". It is working now. I just wanted to make the developers aware of this.
Regards.
Pim
Regards.
Pim
Hardware : AMD Ryzen5 5500 - 3.6GHz / DDR4 40GB / GTX 1080TI
Software : win 10x64 / Octane Render Version 4.05 / SketchUp 2018x64
