Sharp shaded polygons with daylight system
aLeXXtoR
Hi, I have an issue with sharp faces when using daylight system (didn't noticed that when used HDRI map) — here is the simple scene with subdivided monkey model from Blender imported into Octane Standalone 1.20. I have noticed this when worked with more complex scene in Blender.
What am I doing wrong? )
one more example (high density mesh)
Monkey.obj
sample model
(221.37 KiB) Downloaded 252 times
screenshot of the result
Win 10 Pro 64bit | GeForce RTX 2070 SUPER 8Gb | AMD Ryzen 7 3700X | 32GB RAM
WebSite
Showreel
Zay
Try to adjust "Ray Epsilon" to see if that helps.
Win 11 Pro | i5 12600K | 32GB ram | 2x GTX 1080Ti + 3080Ti - studio driver 581.57| Modo/Blender/ZBrush/Daz/Poser
aLeXXtoR
Yes, that helps, but I'm getting an issue with Specular materials.
WebSite
Showreel
Zay
Yes, unfortunately that can happen when adjusting the "Ray Epsilon" and at the same time you have 2 surfaces very close to each other. A work around is to bring in the object scaled bigger until the problem goes away, or adjust the mesh (move the eye a little).
