Daylight animations in Lua
stratified
Hi everybody,
Here's a script to render daylight animations. It has the same functionality as the daylight animation rendering in pre 1.5 releases. The script is a modified version of the turntable script (posted here http://render.otoy.com/forum/viewtopic.php?f=73&t=37456). Fortunately for us, daylight animations are a bit simpler than turntable animations. All we have to do is animate the hour of the sun direction node connected to the daylight environment node. Here's the code:
-- Daylight animation rendering, this script should replace the functionality
-- of the daylight animation pre 1.5.
-- @description Daylight animation rendering
-- @author      Thomas Loockx
-- @version     0.1
-- GUI code
-- creates a text label and returns it
local function createLabel(text)
    return octane.gui.create
        type   = octane.gui.componentType.LABEL,    -- type of component
        text   = text,                              -- text that appears on the label
        width  = 100,                               -- width of the label in pixels
        height = 24,                                -- height of the label in pixels
end
-- creates a slider and returns it
local function createSlider(value, min, max, step, log)
        type        = octane.gui.componentType.SLIDER, -- type of the component
        width       = 400,                             -- width of the slider in pixels
        height      = 20,                              -- height of the slider in pixels
        value       = value,                           -- value of the slider
        minValue    = min,                             -- minimum value of the slider
        maxValue    = max,                             -- maximum value of the slider
        step        = step,                            -- interval between 2 discrete slider values
        logarithmic = log                              -- set the slider logarithmic
end
-- helper to pop-up an error dialog and optionally halts the script
local function showError(text, halt)
    octane.gui.showDialog
        type  = octane.gui.dialogType.ERROR_DIALOG,
        title = "Daylight Animation Error",
        text  = text,
    if halt then error("ERROR: "..text) end
end
-- lets create a bunch of labels and sliders
local startLbl     = createLabel("Start Hour")
local endLbl       = createLabel("End Hour")
local durationLbl  = createLabel("Duration")
local frameRateLbl = createLabel("Framerate")
local frameLbl     = createLabel("Frames")
local samplesLbl   = createLabel("Samples/px")
local startSlider   = createSlider(0, 0, 24, 1, false)
local endSlider     = createSlider(24, 0, 24, 1, false)
local targetSlider  = createSlider(10 , 0.001, 10000, 0.001, true)
local samplesSlider = createSlider(400, 1 , 16000, 1, true)
-- these sliders are couples (25 frames @ 25 fps is 1 second of animation)
local durationSlider  = createSlider(1 , 1 , 3600  , 0.001, true)
local frameRateSlider = createSlider(25, 10, 120   , 1    , false)
local frameSlider     = createSlider(25, 10, 432000, 1    , true)
-- manual layouting is tedious so let's add all our stuff in a group.
local settingsGrp = octane.gui.create
    type     = octane.gui.componentType.GROUP,  -- type of component
    text     = "Settings",                      -- title for the group
    rows     = 7,                               -- number of rows in the grid
    cols     = 2,                               -- number of colums in the grid
    -- the children is a list of child component that go in each cell. The cells
    -- are filled left to right, top to bottom. I just formatted the list to show
    -- where each component goes in the grid.
    children =
        startLbl         , startSlider     ,
        endLbl           , endSlider       ,
        durationLbl      , durationSlider  ,
        frameRateLbl     , frameRateSlider ,
        frameLbl         , frameSlider     ,
        samplesLbl       , samplesSlider   ,
    padding  = { 2 },   -- internal padding in each cell
    inset    = { 5 },   -- inset of the group component itself
-- file output
-- create a button to show a file chooser
local fileChooseButton = octane.gui.create
    type     = octane.gui.componentType.BUTTON,
    text     = "Output...",
    width    = 80,
    height   = 20,
-- create an editor that will show the chosen file path
local fileEditor = octane.gui.create
    type    = octane.gui.componentType.TEXT_EDITOR,
    text    = "",
    x       = 20,
    width   = 400,
    height  = 20,
    enable  = false,
-- for layouting the button and the editor we use a group
local fileGrp = octane.gui.create
    text     = "Output",
    rows     = 1,
    cols     = 2,
    children =
        fileChooseButton, fileEditor,
    padding  = { 2 },
    inset    = { 5 },
-- progress bar
-- eye candy, a progress bar
local progressBar = octane.gui.create
    type   = octane.gui.componentType.PROGRESS_BAR,
    text   = "render progress",
    width  = fileGrp:getProperties().width * 0.8, -- as wide as the group above
    height = 20,
-- for layouting the progress bar
local progressGrp = octane.gui.create
    text     = "",
    rows     = 1,
    cols     = 1,
    children = { progressBar },
    padding  = { 10 },
    centre   = true,    -- centre the progress bar in it's cell
    border   = false,
-- render & cancel buttons
local renderButton = octane.gui.create
    text   = "Render",
    width  = 80,
    height = 20,
local cancelButton = octane.gui.create
    text   = "Cancel",
    width  = 80,
    height = 20,
local buttonGrp = octane.gui.create
    text     = "",
    rows     = 1,
    cols     = 2,
    children = { renderButton, cancelButton },
    padding  = { 5 },
    border   = false,
-- group that layouts the other groups
local layoutGrp = octane.gui.create
    text     = "",
    rows     = 4,
    cols     = 1,
    children =
        settingsGrp,
        fileGrp,
        progressGrp,
        buttonGrp
    centre   = true,
    padding  = { 2 },
    border   = false,
    debug    = false, -- true to show the outlines of the group, handy
-- window that holds all components
local daylightWindow = octane.gui.create
    type     = octane.gui.componentType.WINDOW,
    text     = "Daylight Animation",
    children = { layoutGrp },
    width    = layoutGrp:getProperties().width,
    height   = layoutGrp:getProperties().height,
-- Animation Rendering Code (helpers to get us going)
-- Returns copies of:
--  * the original scene graph
--  * the sun direction node connected to the daylight environment
--  * the render target node
-- These copies prevent us from modifying the original scene
local function getSceneCopy()
    -- get the selected render target
    local selectedRt = octane.project.getSelection()[1]
    -- find the index of the selected render target node
    local idx = -1
    for i, item in ipairs(octane.nodegraph.getRootGraph():getOwnedItems()) do
        if item == selectedRt then
            idx = i
            break
        end
    end
    -- see if we could find the node
    if idx == -1 then showError("no render target selected", true) end
    -- create a full copy of the project so that we don't modify the original project
    local copyScene = octane.nodegraph.createRootGraph("Project Copy")
    copies = copyScene:copyFrom(octane.nodegraph.getRootGraph():getOwnedItems())
    copyRt = copies[idx]
    -- check if the copied node is a render target
    if not copyRt or copyRt:getProperties().type ~= octane.NT_RENDERTARGET then
    end
    -- check if a daylight environment is connected to the render target
    local copyEnv = copyRt:getConnectedNode(octane.P_ENVIRONMENT)
    if not copyEnv or copyEnv:getProperties().type ~= octane.NT_ENV_DAYLIGHT then
        showError("no daylight environment connected to the render target", true)
    end
    -- check if a sun direction is connected to the daylight environment
    local copySunDir = copyEnv:getConnectedNode(octane.P_SUN_DIR)
    if not copySunDir or copySunDir:getProperties().type ~= octane.NT_SUN_DIRECTION then
        showError("no sun direction connected to the daylight environment", true)
    end
    return copyScene, copyRt, copySunDir
end
-- Animates the hour node connected to the daylight environment
local function setHourAnimator(sunDirNode, startHour, endHour, nbFrames)
    -- calculate the new hour for each frame
    local hours = {}
    for i=0,nbFrames-1 do
        -- calculate the hour for each frame
        local hour = startHour + (endHour - startHour) * (i / nbFrames)
        -- store the new hour
        table.insert(hours, { hour, 0, 0 } )
    end
    -- animate the hour
    sunDirNode:getConnectedNode(octane.P_HOUR):setAnimator(octane.A_VALUE, { 0 }, hours, 1 / nbFrames)
end
-- creates a save path for the current frame
local function createSavePath(path, frame)
    local file = octane.file.getFileName(path)
    -- strip png extension
    file = file:gsub("%.png$", "")
    -- split file into prefix, sequence number and suffix
    -- make sure the sequence number is in the final file name part
    local prefix, sequenceMatch, suffix = file:match("(.-)(%d+)([^\\/]*)$")
    -- if the file name doesn't contain a sequence number, the match fails
    -- so just assume it is all prefix.
    if sequenceMatch == nil then
        prefix = file
        sequenceMatch = "0000"
        suffix = ""
    end
    -- pattern for string.format.
    seqPattern = "%0"..sequenceMatch:len().."d"
    -- add png extension
    suffix = suffix..".png"
    -- return the path to the output file
    return octane.file.getParentDirectory(path).."/"..prefix..seqPattern:format(frame)..suffix
end
-- flag indicating cancellation
IS_CANCELLED  = false
function renderCallback()
    -- check if rendering was cancelled
    if (IS_CANCELLED) then
        octane.render.stop()
        return
    end
end
local function startRender(sceneGraph, rtNode, sunDirNode, path)
    -- clear the cancel flag
    -- motion blur doesn't make sense here so we disable it
    octane.render.setShutterTime(0)
    -- disable part of the ui except for the cancel button
    startSlider     :updateProperties{ enable = false }
    endSlider       :updateProperties{ enable = false }
    samplesSlider   :updateProperties{ enable = false }
    durationSlider  :updateProperties{ enable = false }
    frameRateSlider :updateProperties{ enable = false }
    frameSlider     :updateProperties{ enable = false }
    fileChooseButton:updateProperties{ enable = false }
    cancelButton    :updateProperties{ enable = true  }
    -- get the presets from the GUI
    local startHour = startSlider:getProperties().value
    local endHour   = endSlider:getProperties().value
    local nbFrames  = frameSlider:getProperties().value
    local nbSamples = samplesSlider:getProperties().value
    local outPath   = fileEditor:getProperties().text
    -- set up the animator for the hour
    -- start rendering out each frame
    local currentTime = 0
    for frame=1,nbFrames do
        -- set the time in the scene
        sceneGraph:updateTime(currentTime)
        -- update the progress bar
        progressBar:updateProperties{ text = string.format("rendering frame %d", frame) }
        -- fire up the render engine, yihaah!
        octane.render.start
            renderTargetNode = rtNode,
            maxSamples       = nbSamples,
            callback         = renderCallback,
        -- break out if we're cancelled and set it in the progress bar
        if IS_CANCELLED then
            progressBar:updateProperties{ progress = 0, text = "cancelled" }
            break
        end
        -- save the current frame
        local out = createSavePath(path, frame)
        octane.render.saveImage(out, octane.render.imageType.PNG8)
        -- update the time for the next frame
        currentTime = frame * (1 / nbFrames)
        progressBar:updateProperties{ progress = frame / nbFrames }
    end
    -- enable part of the ui except for the cancel button
    startSlider     :updateProperties{ enable = true  }
    endSlider       :updateProperties{ enable = true  }
    samplesSlider   :updateProperties{ enable = true  }
    durationSlider  :updateProperties{ enable = true  }
    frameRateSlider :updateProperties{ enable = true  }
    frameSlider     :updateProperties{ enable = true  }
    fileChooseButton:updateProperties{ enable = true}
    cancelButton    :updateProperties{ enable = false }
    progressBar:updateProperties{ progress = 0, text = "finished" }
end
local function cancelRender()
    IS_CANCELLED = true
end
local function initGui()
    -- render and cancel button are disable
    renderButton:updateProperties{ enable = false }
    cancelButton:updateProperties{ enable = false }
end
-- Main Flow
-- global variable that holds the output path
OUT_PATH = nil
-- Get the render target and sun dir in global variables
SCENE_GRAPH, RT_NODE, SUN_DIR_NODE = getSceneCopy()
initGui()
-- callback handling the GUI elements
local function guiCallback(component, event)
    if component == durationSlider then
        -- if the duration of the animation changes, update the #frames
        local frames = math.ceil(durationSlider:getProperties().value * frameRateSlider:getProperties().value)
        frameSlider:updateProperties{ value = frames }
    elseif component == frameRateSlider then
        -- if the frame rate changes, update the #frames
    elseif component == frameSlider then
        -- if the #frames changes, update the duration of the animation
        local duration = frameSlider:getProperties().value / frameRateSlider:getProperties().value
        durationSlider:updateProperties{ value = duration }
    elseif component == fileChooseButton then
        -- choose an output file
        local ret = octane.gui.showDialog
            type      = octane.gui.dialogType.FILE_DIALOG,
            title     = "Choose the output file",
            wildcards = "*.png",
            save      = true,
        -- if a file is chosen
        if ret.result ~= "" then
            renderButton:updateProperties{ enable = true }
            fileEditor:updateProperties{ text = ret.result }
            OUT_PATH = ret.result
        else
            fileEditor:updateProperties{ text = "" }
            OUT_PATH = nil
        end
    elseif component == renderButton then
        -- get a fresh copy to make sure that when we render the second
        -- time, we start with a pristine state
        startRender(SCENE_GRAPH, RT_NODE, SUN_DIR_NODE, OUT_PATH)
    elseif component == cancelButton then
        cancelRender()
    elseif component == daylightWindow then
        -- when the window closes, cancel rendering
        if event == octane.gui.eventType.WINDOW_CLOSE then
            cancelRender()
        end
    end
end
-- hookup the callback with all the GUI elements
durationSlider:updateProperties   { callback = guiCallback }
frameRateSlider:updateProperties  { callback = guiCallback }
frameSlider:updateProperties      { callback = guiCallback }
fileChooseButton:updateProperties { callback = guiCallback }
renderButton:updateProperties     { callback = guiCallback }
cancelButton:updateProperties     { callback = guiCallback }
daylightWindow:updateProperties   { callback = guiCallback }
-- the script will block here until the window closes
daylightWindow:showWindow()
Here's the code for downloaders:
daylight-animation.lua
daylight animation script
(16.3 KiB) Downloaded 562 times
And here's mr Beep enjoying the sunset:
[youtube]http://www.youtube.com/watch?v=n3766B0Crb4&feature=youtu.be[/youtube]
If there are any questions, please ask.
cheers,
Thomas
Tugpsx
Thanks for sharing. Interesting I got this vector error issue.
Day Light script error
stratified
My mistake, setAnimator expects a list of vectors in 1.23, we relaxed this in 1.24.
I've update the initial post, it should work now.
cheers,
Thomas
Tugpsx
Confirmed working now.
Animated Daylight
Animated Daylight
stratified
okay, thanks for testing!
cheers,
Thomas
Return to “Lua Scripting”
