How to convert CinemaRGB to Octane Float colour with Xpresso
sphericall
I have an material which is composed of 3 mix materials one Glossy and thw Diffuse materials.
All of them are using the same three source colours.
I made and Xpress setup with UserData to easy control source colours in one place.
But I found the problem, how to convert Cinema RGB (1-255 range) to Octane float colour (0-1 range)
I used Range Mapper node like this:
So the Cinema colour is:
RGB 121/141/163 and in Xpresso it gives value accordingly 47.654% 58.433% 64.118%
And for use in octane it should be 0.193 0.301 0.361
Please, help how to convert this weird numbers ;) I know there shoud be Gamma applied somehow...
I'd like to control all colours in one place!!
Win 7 64 bit | 2 x GeForce GTX 660 | Intel Core i7-930 CPU 2,8 GHz | 8GB | Cinema 4d r15 Visualize (no Mograph, no Hair)| OCTANE benchmark scene 2,06 Ms/sec
hi, what about changing the RGB range in the c4d preferences to 0-100%?
in theory you need only to add a math-divide node for getting the correct result
ciao beppe
sphericall
Anyway it doesn't help. Cinema colours must be Gamma correctet to get the Octane values.
Look at this cinema values are 1-100% (lower window) and it is still not the same
plugin converts this colors to linear (SRGB -> LINEAR)
Vector clr = TransformColor(Vector(r,g,b), COLORSPACETRANSFORMATION_SRGB_TO_LINEAR);
are you sure that you need to convert the rgb value?
maybe i have misunderstand but, here is a simple scene without conversion and it seems to work, change the color in the c4d standard material and the three octane materials takes the same color:
color-reference.rar
(121.8 KiB) Downloaded 322 times
ciao beppe
sphericall
I'm some kind of happy now :D
Suppose it is C++, now need to find the way use it in Xpresso by COFFEE or Python script.
sphericall
bepeg4d wrote:are you sure that you need to convert the rgb value?
color-reference.rar
ciao beppe
Finally I did it the same way, but as I need to change 3 colors I made nice Setup with UserData and Xpresso, like this:
And my goal was not to generate new Materials. Now one material definition looks like that.
And my COLOR CONTROL Diffuse channel looks like that:
It is not the best setup in terms of usability. But it works :)
Thanks.
Here is my setup. Look into the Xpresso tag.
color-control.zip
