Script to create Lua API documentation in html.
stratified
hi there,
For the people who don't like the API browser. I wrote a Lua script a while ago to create a html file describing the Octane Lua API. The script will ask for an output file.
create-docs.lua
html documentation creation script
(11.72 KiB) Downloaded 869 times
create-docs_213.lua
html documentation creation script for Standalone v2.13+
(11.7 KiB) Downloaded 1247 times
cheers,
Thomas
Tugpsx
Output error with script
Lua doc error
Lua doc error
Also text in the Output area of the editor doesn't copy to clipboard
stratified
Hi there,
I modified the script to dump out an error when doc is nil. This can happend when that file is not writable. Could you try to use a different path in the variable HTML_FILE?
thanks,
Thomas
-- Creates a single html that describes the Lua API. Run this thing from
-- within Octane. It creates a file api.html next to the Octane binary.
local HTML_FILE = "/tmp/api.html"
doc, errMsg = io.open(HTML_FILE, "w")
if not doc then error(errMsg) end
local cssStyle =
body
    font-family: 'Titillium Web', Verdana, Helvetica, sans-serif;
h1
    color: #d50708;
h2
    color: #d50708;
    border-bottom: 1px solid #d50708;
h3
    color: #3083aa;
    border-bottom: 1px solid #3083aa;
a
    color: #FF6600;
a:hover
    color: white;
    background-color: #FF6600;
table.funcdoc
    padding-top: 10px;
table.funcdoc th
    color:#4b6a7e;
    padding-right: 40px;
local function inArray(array, value)
    for _, val in ipairs(array) do
        if value == val then return true end
    end
    return false
end
-- Inline CSS style
doc:write("<html>")
doc:write("<head>")
doc:write(string.format("<style>%s</style>", cssStyle))
doc:write("</head>")
doc:write("<body>")
-- Logo
doc:write('<div class="logo" style="left: 200px; opacity: 1;">')
doc:write('<img src="http://render.otoy.com/images/octanerender_logo.png" width="58" height="65" alt="Octane Render Logo" class="spinme">')
doc:write('<img src="http://render.otoy.com/images/octanerender_text.png" width="206" height="65" alt="Octane Render">')
doc:write('</div>')
doc:write("<h1>Lua API<h1>")
local modules = octane.help.modules()
-- Module overview.
doc:write("<h2>Modules Overview</h2>")
doc:write("<table class='overview'>")
for name, description in pairs(modules) do
    doc:write(string.format("<tr><td><a href='#%s'>%s</a></td><td>%s</td></tr>", name, name, description))
end
doc:write("</table>")
-- Per Module breakdown.
for moduleName, description in pairs(modules) do
    doc:write(string.format("<h2 id='%s'>Module %s</h2>", moduleName, moduleName))
    doc:write(string.format("<p>%s</p>", description))
    -- Table with functions.
    local modfunctions = octane.help.functions(moduleName)
    doc:write("<h3>Functions</h3>")
    for _, func in ipairs(modfunctions) do
        local funcdoc = octane.help.functionDoc(octane[moduleName][func])
        local fullName = string.format("octane.%s.%s", moduleName, func)
        doc:write(string.format("<tr><td><a href='#%s'>%s</a></td><td>%s</td></tr>", fullName, fullName, funcdoc.description))
    end
    -- Table with the properties.
    local moduleProps = octane.help.properties(moduleName)
    if #moduleProps > 0 then
        doc:write("<h3>Properties</h3>")
        for idx, propsName in ipairs(moduleProps) do
            local propsDoc = octane.help.propertiesDoc(moduleName, propsName)
            local fullName = string.format("octane.%s.%s", moduleName, propsName)
            doc:write(string.format("<tr><td><a href='#%s'>%s</a></td><td>%s</td></tr>", fullName, fullName, propsDoc.description))
        end
    end
    -- Table with the constants.
    local moduleConstants = octane.help.constants(moduleName)
    if #moduleConstants > 0 then
        doc:write("<h3>Constants</h3>")
        for idx, constantName in ipairs(moduleConstants) do
            local constantInfo = octane.help.constantDoc(moduleName, constantName)
            local fullName     = string.format("octane.%s.%s", moduleName, constantName)
            doc:write(string.format("<tr><td><a href='#%s'>%s</a></td><td>%s</td></tr>", fullName, fullName, constantInfo.description))
        end
    end
end
-- Give a breakdown per function.
doc:write("<h2>Function Overview</h2>")
for moduleName, moduleDescription in pairs(modules) do
    local moduleFunctions = octane.help.functions(moduleName)
    for _, functionName in ipairs(moduleFunctions) do
        local fullName = string.format("octane.%s.%s", moduleName, functionName)
        doc:write(string.format("<h3 id='%s'>%s</h3>", fullName, fullName))
        local funcDoc  = octane.help.functionDoc(octane[moduleName][functionName])
        local modProps = octane.help.properties(moduleName)
        doc:write("<span class='funcdoc'>")
        -- Table with the description.
        doc:write("<table class='funcdoc'>")
        doc:write("<tr align='left'><th>Description</th></tr>")
        doc:write(string.format("<tr><td>%s</td></tr>", funcDoc.description))
        -- Table with the parameters.
        if #funcDoc.params > 0 then
            doc:write("<tr align='left'> <th colspan='3'>Parameters</th> </tr>")
            doc:write("<tr align='left'> <th>Name</th> <th>Type</th> <th>Description</th> </tr>")
            for _, param in ipairs(funcDoc.params) do
                if (not inArray(modProps, param.name)) then
                    -- regular param
                    doc:write(string.format("<tr> <td>%s</td> <td>%s</td> <td>%s</td> </tr>",
                                            param["name"], param["type"], param["description"]))
                else
                    -- property
                    doc:write(string.format("<tr> <td><a href='#%s'>%s</a></td> <td>%s</td> <td>%s</td> </tr>",
                                            string.format("octane.%s.%s", moduleName, param.name),
                                            param["name"],
                                            param["type"],
                end
            end
        end
        -- Table with return values.
        if #funcDoc.returns > 0 then
            doc:write("<tr align='left'> <th colspan='3'>Return Values</th> </tr>")
            for _, ret in ipairs(funcDoc.returns) do
                if not inArray(modProps, ret.name) then
                    -- regular return value.
                    doc:write(string.format("<tr> <td>%s</td> <td>%s</td> <td>%s</td> </tr>", ret["name"], ret["type"], ret["description"]))
                else
                    -- property return value.
                                            string.format("octane.%s.%s", moduleName, ret.name),
                                            ret["name"],
                                            ret["type"],
                end
            end
        end
        -- Create the synopsis.
        local synopsis = ""
            for i=1,#funcDoc.returns-1 do
                synopsis = synopsis..funcDoc.returns[i].name..", "
            end
            synopsis = synopsis..funcDoc.returns[#funcDoc.returns].name.." = "
        end
        synopsis = synopsis..fullName.."( "
            for i=1,#funcDoc.params-1 do
                synopsis = synopsis..funcDoc.params[i].name..", "
            end
            synopsis = synopsis..funcDoc.params[#funcDoc.params].name
        end
        synopsis = synopsis.." )"
        -- Table with the synopsis.
        doc:write("<tr align='left'><th>Synopsis</th></tr>")
        doc:write(string.format("<tr align='left'><td>%s</td></tr>", synopsis))
        doc:write("</span>")
    end
end
-- Give a breakdown per constant.
doc:write("<h2>Constant Overview</h2>")
    local constantNames = octane.help.constants(moduleName)
    for _, constantName in ipairs(constantNames) do
        local constDoc = octane.help.constantDoc(moduleName, constantName)
        doc:write(string.format("<tr><td>%s</td></tr>", constDoc.description))
        -- Table with the constant values.
        doc:write("<tr align='left'><th>Values</th></tr>")
        -- Get the names.
        local names = {}
        for name, _ in pairs(constDoc.values) do
            table.insert(names, name)
        end
        -- Sort the names.
        table.sort(names)
        for _, name in ipairs(names) do
            doc:write(string.format("<tr> <td>%s</td> </tr>", name))
        end
    end
end
-- Give a breakdown per properties.
doc:write("<h2>Properties Overview</h2>")
    for _, propertiesName in ipairs(moduleProps) do
        local fullName = string.format("octane.%s.%s", moduleName, propertiesName)
        local propertiesDoc = octane.help.propertiesDoc(moduleName, propertiesName)
        doc:write(string.format("<tr><td>%s</td></tr>", propertiesDoc.description))
        local properties = propertiesDoc.properties
        local propNames  = {}
        for name, _ in pairs(properties) do
            table.insert(propNames, name)
        end
        table.sort(propNames)
        -- Table with each proprty
        doc:write("<tr align='left'> <th colspan='3'>Properties</th> </tr>")
        doc:write("<tr align='left'> <th>Name</th> <th>Description</th> <th>Type</th> <th>Writable</th></tr>")
        for _,name in ipairs(propNames) do
            local info = properties[name]
            doc:write(string.format("<tr> <td>%s</td> <td>%s</td> <td>%s</td> <td>%s</td> </tr>",
                                    name, info.description, info["type"], info.writable))
        end
    end
end
doc:write("</body>")
doc:write("</html>")
stratified
Tugpsx wrote:Also text in the Output area of the editor doesn't copy to clipboard
just noticed that as well, we'll fix it in one of the next releases.
cheers,
Thomas
Tugpsx
Can we add an option to clear the output in the editor also. This will help a lot with debugging script outputs
Tugpsx
Output works great now. But better yet add an option for it to prompt the user for the location to save the file. End user will appreciate it.
stratified
This will show a dialog asking the user where to save the file. It pops up an error if something went wrong.
But then again I guess the people who're interested in Lua could have figured this out themselves ;)
cheers,
Thomas
-- show the user a file chooser
result = octane.gui.showDialog
    type      = octane.gui.dialogType.FILE_DIALOG,
    title     = "Choose Lua API html doc output",
    wildcards = "*.html;*.htm",
    save      = true
-- try to open the file and show an error dialog if it failed
doc, errMsg = io.open(result.result, "w")
if not doc then
        type  = octane.gui.dialogType.ERROR_DIALOG,
        title = "File error",
        text  = errMsg
    -- stop the script
    error(errMsg)
end
local cssStyle =
body
h1
    color: #d50708;
h2
    color: #d50708;
h3
    color: #3083aa;
a
    color: #FF6600;
a:hover
    color: white;
table.funcdoc
    padding-top: 10px;
table.funcdoc th
    color:#4b6a7e;
    end
    return false
end
-- Inline CSS style
doc:write("<html>")
doc:write("<head>")
doc:write("<body>")
-- Logo
doc:write('</div>')
-- Module overview.
end
    end
        end
    end
        end
    end
end
                    -- regular param
                else
                    -- property
                                            param["name"],
                                            param["type"],
                end
            end
        end
                else
                                            ret["name"],
                                            ret["type"],
                end
            end
        end
        local synopsis = ""
            end
        end
            end
        end
    end
end
        -- Get the names.
        local names = {}
        end
        -- Sort the names.
        table.sort(names)
        end
    end
end
        end
        end
    end
end
matej
Quick question about documentation: where can I get all the parameter info that the octane.node.create() function gets? ie. this:
• table PROPS_NODE_ITEM
Table with properties for the node.
I would like to generate a node graph, basically a shader. But dunno how to assign which is the parent container (node graph) to nodes.
Maybe the next tutorial could be about how to set up a generic node graph shader programatically, with texture loading from disk and all the usual stuff (setting pins, connections, mixing materials or textures...)? :)
Anyway, great work with implementing scripting. Thanks!
EDIT: ah, sorry, I got it. Was at the end of the list. To specify where the node is created, I must use the "graphOwner" param. :)
cgmo.net
stratified
matej wrote: Maybe the next tutorial could be about how to set up a generic node graph shader programatically, with texture loading from disk and all the usual stuff (setting pins, connections, mixing materials or textures...)? :)
I'll create a post explaining all this...
cheers,
Thomas
ultrafish
This script is crashing with the current demo version of octane because octane[moduleName] == nil when moduleName == 'benchmark' or 'octane'. The crash happens on lines 122 and 164. I was able to put checks in for myself, but I didn't want to post my code since I'm very new to octane and I thought it might be an issue only with the demo version.
Thanks.
Return to “Lua Scripting”
