When import the texture its gray on render, whats up ?
its happen if import the texture for first time through plugin
and dont happen if put texture map through poser ..
all texture map are gray ?!
Can you post a screenshot of the Octane node pls? And what version of the plugin are you using pls?
Try and take a look at the specular nodes for each texture that you have in your scene.
They sometimes get imported with values which are fine for Poser but are way to high for the much more light sensitive lighting environment of Octane.
So turning the specular values down from 1 to about 0.3 - 0.5 (depending on the material and the look you're trying to achieve) it should render fine with all the textures.
W10 64 bit | i7 3770K | MSI Geforce RTX 2080 (8GB) + GTX Titan Black (6GB) | 32 GB DDR3 RAM
- Andygraph3D
its a my error
i have select floatimage but i need select "image" for load color picture
