Hi all, found a possible bug and if not a bug a huge annoyance....
I just completed setting up my scene, materlais, lighting, camera everything. Final render then post, send proof to client. Needed a couple object/surface masks and an alpha pass etc so I 'Switched to LW' renderer to output those. Saved Scene (big mistake). When re-opening my scene ALL the nodes in the Editor are gone and I'm left to re-create them as best my memory serves.
I wouldn't have thought 'Switch to LW' would delete all my Editor Nodes, rather.. switch to LW renderer and then switch back to Octane with all my editor nodes intact. If this is how the LW plugin is supposed to work, at the very least there should be a warning before swithcing to LW renderer that all editor nodes will be lost.
Hopefully this can be fixed in time for the next plugin release.
							"Switch to LW"... all Editor Nodes Gone!
i see what you mean,
very usefull to know that before
sorry for your work buddy, but your experience could be usefull for the communoty
thanks
thanks
I just noticed in the latest plugin release 1.20.6 if you switch to LW, octane saves out the render target.. is this new in 1.20.6 or has it always been there?
							Dino Inglese
CG Artist
Melbourne Australia
Intel Core i7-4820K, 3x GTX 980ti
Windows 7 64bit, Modo 12.2v2 for PC
Octane build 4.04.0.145
						CG Artist
Melbourne Australia
Yes, it saves the render target to a temp file to load it later when you switch to Octane.Reversion1970 wrote:I just noticed in the latest plugin release 1.20.6 if you switch to LW, octane saves out the render target.. is this new in 1.20.6 or has it always been there?
