Octane v1.01 rendering issue
Forums: Octane v1.01 rendering issue
Postby motiong » Fri Nov 15, 2013 9:29 pm
motiong Fri Nov 15, 2013 9:29 pm
Octane v1.01 is rendering noise. My graphic card has cuda. It's GeForce GT 555M, i7, 6GB of RAM, Windows8 64bit. Tried with older and latest drivers. Whats the solution? I found out that the noise is only in preview window, the rendered frames are ok.
motiong
Re: Octane v1.01 rendering issue
Postby face » Fri Nov 15, 2013 10:01 pm
face Fri Nov 15, 2013 10:01 pm
Yes, that is an issue which is fixed in the next release.
You can reduce the resolution or uncheck the "Autofit viewer" in the preview options to make it invisible.
This issue only affects the preview/render window.
The saved images from a frame or pass rendering ore ok.
face
http://vimeo.com/user2509578
face
Postby motiong » Fri Nov 15, 2013 10:06 pm
motiong Fri Nov 15, 2013 10:06 pm
Thanks Face, the reduced resolution helped.
motiong
Mon Jun 03, 2024 1:15 pm [ UTC ]
