worn edges/ worn paint shader for c4d - giveaway
djart
Hello all,
i like to share my version of an worn edges/ paint shader for c4d.
After some research on how to build a worn edges shader, i found some links that helped to understand.
Its pretty simple if you know how :)
http://render.otoy.com/forum/viewtopic. ... rt#p154262
http://render.otoy.com/forum/viewtopic. ... rn#p122269
http://render.otoy.com/forum/viewtopic. ... rt#p143914
http://render.otoy.com/forum/viewtopic. ... rt#p150475
It works pretty well for the most solutions.
Everyone is free to tweak the shader for their own needs.
The size and more can be controlled by the values from the dirtshader, located in the MIX MAT.
The textures are taken from http://www.cgtextures.com
The plugin http://c4dtools.net/chamfer-maker/ is used for one scene and
you need to use your own HDRI for the scenes.
djart
worn_edge-paint_octane_2013.rar
(3.11 MiB) Downloaded 487 times
cleanerxx
looks great!
thanks for contributing!
Win10x64 | 2xgtx780 6gb | i7 3930k | 32GB | octane for c4d 4.05-R7 | nvidia 466.47
wireframex
Good idea and thanks fo sharing this :)
Main Computer:
Ryzen 3990X / 96Go Ram / 2 x RTX 3090
OS: Windows 11 x64 - NVidia Driver 560.70 - Octane Plugin Build 2023.1.3.141
Licensed: Softimage 2012 SP1 / Lightwave 2024.0.1 / Rhino 8.9
