1. OctaneRender™ Server
The first part (server) should be run on the same computer as the second one..
- Added "Subframe Motion Blur" feature. So far the "Movable proxy" objects feature is not fully implemented, so this motion blur will work not with the full possible speed. After "Movable proxy" feature will be implemented in next versions - this motion blur feature will become a lot faster...
 - Added "Interpolated vertex normals" info-channel type.
 - Minor improvements and bug fixes...
- Just run the installer to see its command line keys.
- If you need to run the OctaneServer - run it as daemon:
# OctaneServer &DOWNLOAD
Blender Octane Edition - v2.6 beta Linux (128MB autoinstaller file)
