Noob alert!
- jeremiah.karl
- Contact:
Ok guys am realy a noob like extremely new to all this!Iv been following the whole orbx.js thing and although i dont fully understand it am getting to know all about it and am realy fascinated
Quick fact...am mainly just a gamer!Anyway so iv been trying to find a way to stream a video or a game of some sort just to test this whole orbx.js thing out!Id be realy happy if some one would help me out!Currently iv just signed up to AWS but i have no clue what to do!Thanks alot guys and hope am welome to this awesum community!
I recommend you wait a few weeks (if all goes according to schedule) - with the launch of OctaneCloud, you will get a one click launch of your own Amazon VM with a GPU for $19/month (300 minutes + 100 GB HD) without having to be an AWS developer or go through the fairly technical steps need to set up the Amazon AMI. Additional time will be ~$1/hr (depending on the region), and additional storage will be about 10c/GB.
- jeremiah.karl
- Contact:
Ok but its cool..i kinda found my way around stuff!Now i know how to lanch an instance yay!
Anyway...so how do i acess the G2 instance?All i see is winodws and linux!
You want to create an instance by select Launch Instance, then do a slect from AMI Marketplace, type ORBX. Then select the Autodesk version. Once you are happy with that you then need to select the type of instance, you want to to choose the GPU category, and in there, there is only one choice G2. From then on should be self explanatory
- jeremiah.karl
- Contact:
Yh i somehow managed to go froom noob to semi noob and now am in already!But am getting Time out like everyone else!Seems to be the whole GUID thing!SimonG wrote:You want to create an instance by select Launch Instance, then do a slect from AMI Marketplace, type ORBX. Then select the Autodesk version. Once you are happy with that you then need to select the type of instance, you want to to choose the GPU category, and in there, there is only one choice G2. From then on should be self explanatory
Timeour here as well. RDP works, GUID shows up in task manager.
doing wmic PROCESS get Caption,Commandline | FIND "GUID=" in the commmand line throws the error File not found - PROCESS get Caption - Alias not found.
SEHSUCHT Berlin - 22x GTX 780
Also, Octane isn't installed at all inside MAX?
The full version of the standalone can be launched in AMI - it doesn't need to be installed. But this not the case with plug-ins at the moment. We'll be implementing this mechanism for the plug-ins down the line
For now, to use full version of the the max plug-in, you need to install your own SA and plug-in license just as with a local machine. Also note that this is a trial version of Max. Our plan is to get the cloud licensed plug-ins auto installed once we see what the final version of Max without the trial looks like (that is up to Autodesk, not us).
