batch rendering with the demo version?
Moderator: JimStar
mixepix
Hi!
Is it possible to batch render with the demo version of the plugin? When I try to batch render with it nothing shows up in my render folder and I'm not sure if it's a bug or just something that is disabled.
Cheers
Mikael
JimStar
You can enable the "Verbose mode" in Octane settings, and check the batch render log for errors.
mixepix
Thanks, I turned on Verbose mode but I don't get any errors in the mayaRenderLog.txt-file? It looks like it renders just fine but I still don't get any files in the output folder. :(
JimStar
mixepix wrote:Thanks, I turned on Verbose mode but I don't get any errors in the mayaRenderLog.txt-file? It looks like it renders just fine but I still don't get any files in the output folder. :(
Can you please attach here the log file?
mixepix
Sure, here it is.
mayaRenderLog.rar
(1.35 KiB) Downloaded 243 times
JimStar
Yes, all works OK on your machine, no errors in the log file.
It is just demo-version restriction, that it can't save any rendered images at all...
mixepix
Ah, ok as I suspected. Thanks.
Return to “Autodesk Maya”
