did you apply the registry fix on the laptop ?Whichway wrote:Yes and yes.radiance wrote:does that driver support cuda 3.0 ? did 2.1 work on it ?Whichway wrote: Laptop: 8600M GT with 197.16 driver
Whichway
Radiance
Whichway
Radiance
Whichway
Radiance
Whichway
so does a propper model render fine now ?candide wrote:Testing the vertex normals (from Moi and such) - it's much better now, the polygons are shaded, but there's some kind of weird "shadow" appearing under some angles when I move the camera (see pic). It happens with both daylight and environmental lighting. Test obj attached
Minor bug: the render display shows 60/0 MB memory used even though the device manager detects my total memory correctly
I tell a lie. Actually, 1.021 has the same behavior - directlight works fine but pathtrace does not - stops the driver.Whichway wrote:Yes and yes.radiance wrote:does that driver support cuda 3.0 ? did 2.1 work on it ?Whichway wrote: Laptop: 8600M GT with 197.16 driver
Whichway
Radiance
Whichway
Umm, what registry fix?radiance wrote: did you apply the registry fix on the laptop ?
Radiance
thanks, but we definately should see if we can fix that... it's quite stable on our hardware setups. (changing res on the fly)katerlake wrote:On the first look, this RC is faster then the old version. The mix function is great.
Resolution changing during the rendering dont work with my system, but with this problem, i can live.![]()
My system: Win 7 64 bit, GTS 250, Octane 1.022 beta2.2 RC1 64bit
@ Radiance. You and your team make an great Job.
http://www.refractivesoftware.com/forum ... f=21&t=824Whichway wrote:Umm, what registry fix?radiance wrote: did you apply the registry fix on the laptop ?
Radiance
Whichway
seems to work here, can anyone else confirm ?MagnusL3D wrote:Bump doesnt seem to work for me in 2.2 RC1 anyone else confirm ? I've tried several different textures and also did the jump between pathtracing and direct trick to see if that helped but nothing does.
/M
Hi Radiance,radiance wrote:it's noted, we'll check it for RC2.Faizol wrote:Thanks for the command line options.radiance wrote: works fine here... ?!
Btw, (on Linux) I tried multiple variations; ./octane --help, ./octane -h, ./octane --Help, ./octane --HELP, ./octane -?, all went straight into UI.
Radiance
