Yup... that fixed it.
Thanks Paul.
OctaneRender® for Poser (Windows) - build 1.20.2 [OBSOLETE]
RAM: 64GB
OCTANE PLUGIN VERSION: 2025.6.0.4.09 Prime BETA
DAZ STUDIO VERSION: 4.24 Pro Edition (64 bit)
RAM: 64GB
So I'm here in the wee small hours thinking while rendering... yeah hard to do... that it would be good if under "Setup" we could select an Output folder for progressive save and have it 'sticky' default everytime we used or loaded Octane.
Time to go back to bed I think.
RAM: 64GB
RAM: 64GB
Good idea! I'll pop this in the next version.So I'm here in the wee small hours thinking while rendering... yeah hard to do... that it would be good if under "Setup" we could select an Output folder for progressive save and have it 'sticky' default everytime we used or loaded Octane.
I have updated the installers at the top of this thread. Pls download and reinstall if you want:
1.20.2.5
- Removed PROGRESSIVE_SAVE_OUTPUT_FOLDER from the OctaneDefaults.py and the last selected progressive save folder is stored in Config.xml
- Added V6 skin materials to the skin materials list in OctaneDefaults.py (IMPORTANT: you will need to rename your old OctaneDefaults.py file prior to run the installer in order for this change to be made)
- Added support for the new Otoy LiveDB category
- The Resolution Lock status is now saved to the pz3, so when you load a pz3 file, it will retain the Resolution Lock status it was saved with
1.20.2.5
- morphious2013
Still would really like to see a "Render" queue. Tired of frame by frame, making sure I keyframe all figures before going to the next one. I'm sure it's not a big request, but would be nice to render a series of poser scene files. Thanks.
Randall.
Randall.
Gateway i5 3.2ghz, 16g RAM, GTX 690 4GB VRAM, Windows 10 64bit, Poser Pro 11, DAZ Studio Pro 4.9, Daz Octane Plugin V2, Poser Octane Plugin V2
The new sticky "Save progressive thing" isn't as sticky as I'd like. After a crash, it's gone and between stopping and starting poser it isn't there.
RAM: 64GB
RAM: 64GB
Hi Randall. This is quite a bit of work to implement, and there is a good possibility that Octane 1.5 will provide an alternate solution to the render queue. So I'm waiting until Octane 1.5 before proceeding with this.Still would really like to see a "Render" queue. Tired of frame by frame, making sure I keyframe all figures before going to the next one. I'm sure it's not a big request, but would be nice to render a series of poser scene files. Thanks.
Hi Deane. What were the details of the crash? Was it Octane, Poser, the plugin? If you start Poser, and the Progressive Save Folder has not been remembered, could you post or email me your config.xml and octaneplugin.log files (after you've started Poser and started the plugin but not rendered yet).The new sticky "Save progressive thing" isn't as sticky as I'd like. After a crash, it's gone and between stopping and starting poser it isn't there.
Hi Paul...
Started Poser...
Started the plugin...
Your standard default is displayed for Progressive saves...
Changed it to my default folder.. and saved.
Closed the plugin, closed Poser.
Restarted Poser, restarted the plugin.
Still displays your default folder and not mine.
Remind me again where I find the 'config.xml' file please.
Started Poser...
RAM: 64GB
RAM: 64GB
C:\Users\[username]\AppData\Roaming\Poser Pro\10.Remind me again where I find the 'config.xml' file please.
Thanks Deane.
Can I attach it here... I'll try...
- config.zip
- Had to zip it... xml not allowed
- (625 Bytes) Downloaded 255 times
RAM: 64GB
RAM: 64GB
