split screen ghost after shut-down
tnarch
if i have the OR render window opened on the second screen and go to shut down without dragging it back to the main screen or changing the display mode to 1 screen, i will not see the render window when i boot up again without the second monitor hooked in. the strange thing is when i press alt+tab, i will see two screens. both exactly the same. this doesn't happen with any other app i run.
how do i get the OR window back? thx
Hi
Which version of the plugin are you running pls?
Does deleting C:\Users\Paul\AppData\Local\OctaneRender for Rhinoceros\config.xml, fix the problem?
I have refreshed the latest 64bit TEST build to hopefully assist with this issue. Pls see test build thread for details.
tnarch
latest build solved the problem. thanks!
T
Return to “Rhinoceros 3D”
