noise reduction
Arhitectu
You have any bump map set to wall material?
slepy8 wrote:I changed sizes.
But unfortunatelly no effect.
Hot pixels pop up in the same places..
sample.zip
(609.6 KiB) Downloaded 276 times
slepy8
Thanks Aoktar!
Your scene shows some hot pixels in the beginning but they are lost in time, giving clean image in the end...
I'm going through your scene to figure out what I screwed up with. It's a good lesson ;)
Thank you
pokeit
I noticed the sample rate on all his lights were at 1. Is that it? Do please pass on any info you glean...
2xI7 3930K 3.2ghz/32gig/Win10ultsp1 1xI7 6950X @4.0ghz 2x Titans 1x 780ti 3x 980ti
C4DR15 OctaneC4D 3.03.3 SDK 3.03.3 Mobo: AsusP9X79 Pro
slepy8
ok
I started using proper scaling, so what's 100cm in real life is 100cm in C4D.
Now I don't have to give each light 20'000 power.. Now 100 or 200 is enough in most cases.
The way of mounting the light is different. I used some torus to give the light proper modulation. Now I just use extrude inner, and extrude so the light is in some sort of "tube" inside the ceiling.
I'm using light sampling at "1" value. No idea if it changes anything, but it doesn't hurt too ;)
Honestly - in every new scene the hotpixels dissapeared...
Below the "straight-from-C4D" image after small color correction (no other retouch).
I'm rendering the pmc/5 shot now, but it will take next 5hrs cuz I'm willing to give it a downscale.
Seams like the scene sizes were an issue....
So thanks to iFloris for giving a good hint. ;)
cheers!
PS: below is DL/diffuse, 6/6 / diffusedepth:3. maxsamples:4000
slepy8
PMC/5 maxdepth: 10'000
hotpixel value: 1
no downscale, "straight-from-c4d" image
NO NOISE!! :D
thanks guys!
Rudi
What signifies PMC / 5?
iFloris
slepy8 wrote:PMC/5 maxdepth: 10'000
hotpixel value: 1
NO NOISE!! :D
thanks guys!
Glad you figured it out and was able to get a really clean render.
Win 7 pro 64 | 3 x Asus GTX Titan | i7 3930 OC 4.2 | 32GB | Octane Cinema4D plugin | R14
hotpixel value: 1
NO NOISE!! :D
thanks guys!
i wish to share that have a idea about adding some opensource noise removal tools to plugin
iFloris
aoktar wrote: i wish to share that have a idea about adding some opensource noise removal tools to plugin
Well, thanks for sharing and that would be an awesome addition in my opinion!
