OctaneBench Competition - Turbocharger - Final
Please create a topic in here for your entry into the competition.
Please create one topic in here for you entry into the competition.
kubicki3d
Hi All!
Here are some early renderings of a turbocharger.
I'm not sure yet but maybe I'll try to add some background objects (eg. put the turbo on a table, add some tools). I'll experiment with it if time allows.
All renderings below 2,5 mins on a Quadro 4000 (stopped at 500 samples).
Cheers,
Szymon
i7 5960X | 64GB RAM | Win10 Pro | ASUS X99 Pro mobo | Chieftec 1250W psu
MSI GTX 780 Ti OC 3GB | 2 x GIGABYTE GTX 780 OC 3GB on USB risers | MSI GTX 750 Ti for display
Blender + Octane | C4D + Corona
Flickr profile: http://www.flickr.com/photos/kubicki3d
Andreas.visjon
nice idea. I think you shut put something more in the scene, or something where the turbocharger belongs to.
Maye you will find time to model a computer case where the turbo is connected.
Ciao
Andreas
_________________
Win7 Prof | MSI X99S SLI Krait Edition | Geforce GTX980 4GB | 5820K | 16GB
kubicki3d
Thanks man! Your idea is certainly worth giving it a try.
BTW good to see progress of your work - I love the theme that you've chosen!
cheers,
Szymon
kubicki3d
Plugging a turbo to a PC seems illogical - but it works!
Thanks for the advice Andreas.visjon
kubicki3d
This is probably one of the last mods I will make to this project.
PT 6, 350 samples take 120 sec. on a Quadro 4000.
Only procedural textures used.
Zipped ocs and objs fit under 6 MB.
Cheers,
Szymon
OctaneBench_kubicki3d_Turbocharger.zip
(5.59 MiB) Downloaded 1696 times
Andreas.visjon
Yeah nice one, something like this i had in mind. ;)
_________________
eidy
Should you want / need to shorten that render time further you could try lowering the PT max depth value (to no less than 2) + you could also set a bigger ray epsilon value (to no more than 0.1). Balancing those two could save time with minimal quality impact.
All best
eidy
kubicki3d
Thanks eidy!
There was indeed some space for the changes that you've suggested. Ray epsilon went up to 0.00025, max depth - down to 5 (the light losses were small enough to be partly compensated by raising the lamp power). Unfortunately anything beyond those values caused some visible quality issues.
I also noticed that there is no need to set the max samples value to more than 250.
All this saved over 30 seconds of rendering. The time is now just below 1:30 on a Quadro 4000.
Cheers,
Szymon
(5.59 MiB) Downloaded 1580 times
kubicki3d
Funny thing - raising the field of view to 65 saved me 2 seconds of rendering time (currently 1:28, Quadro 4000).
So, this is the final version of the turbo.
Good luck everyone
Szymon
(5.59 MiB) Downloaded 1705 times
Return to “The OctaneBench Competition Entries”
