Yes good remark, no noise at all on the glass after 1mn45sec with two gtx 260.[gk] wrote:…looks fun anyways..
especially the glass lacking noise.
Iray tests on CGTalk
Work Station : MB ASUS X299-Pro/SE - Intel i9 7980XE (2,6ghz 18 cores / 36 threads) - Ram 64GB - RTX4090 + RTX3090 - Win10
Net render : MB Asus Pro WS W790E-SAGE SE - XEON - 128GB - 2 x RTX 3090 - 3 x RTX 2080TI
i also see no caustics...pixym wrote:Yes good remark, no noise at all on the glass after 1mn45sec with two gtx 260.[gk] wrote:…looks fun anyways..
maybe it's not full pathtracing, like arion, eg they leave out certain path types, resulting in no caustics / no fireflies.
Radiance
Thanks for the explanation Rad.
You are very aware of the render naiborhood
There seem to be caustics here:radiance wrote:i also see no caustics...
Radiance
http://forums.cgsociety.org/showpost.ph ... ostcount=7
Well, those caustics looks very subtle, and pathtraced ^^
Octane already produced better looking caustics then that
Cheers.
Chris
Cheers.
Chris
________________________________________________________
Win 7 64 | 1x GeForce GTX Titan | AMD Phenom II X6 3.20Ghz | 16GB
The youtube video look good, but not as good as Octane. Granted a lot of that could be the way the file was set up. Everything still looks plastic like, not real.
System 1: EVGA gtx470 1280Mb and MSI gtx470 1280 in Cubix Xpander for Octane, AMD 945, 4Gb Ram
All systems are at stock speeds and settings.
i think they are somewhat limiting the rendering equation, eg limiting the unbiasedness by either leaving out certain light interactions,
or not multiplying PDFs, which does'nt give fireflies, but it does give incorrect results.
arion does the same currently (they simply cut out caustic paths, so it's not unbiased)
we on de the full render equation, every bounce is accounted, also caustics, therefore the fireflies.
MLT will fix that though. let's hope we can finish it smoothly with no big issues and we'll have 2.3 released asap.
Radiance
Radiance
well that's we are looking forward from Octane
is that an emitter rendering image in iray? Since I've been working at architecture design office, we do need light emitters in the scene. I'm very excited to hear that the emitter function will be implemented in 3.0
if we have time enough we might add it to the next release after the 2.2 which will be released as RC tomorrow,hiron wrote:well that's we are looking forward from Octane![]()
so that will be 2.3.
however, that's not a promise.
Radiance
I have just seen a set of videoz from a new gpu renderer here:
http://forums.cgsociety.org/showpost.ph ... stcount=75
