Testing Beta 0.87b (SDK 1.20) **updated 04.10**
dinf wrote:
aoktar wrote:
dinf wrote:Ahmet is there a possibility to use the visibility function of the displya tag, or something similar in Octane? I have to smoothly blend in and out many machine parts wich I normally do via this tag, but Octane ignores it wich leads to an effect like switching a separate light on and off in the camera view, though this parts are in the off.
plugin only support on/off effect now via tags. You should try material opacity or mix materials.
But this kind of support must be in development
The opacity can be animated in Octane? Wow, didn't see that.
What do you mean with the mix materials, animate a FloatTexture to blend between material A and B, something like that?
yes everything can be animated.
With mix material you can use a unvisible material and others and floattexture can do transation
Bulwerk
I am having trouble installing and launching. I am sure i am making a stupid mistake somewhere.
Here are two images that show where I installed and the error i get when I launch C4D.
Help would be much appreciated!
Bulwerk wrote:I am having trouble installing and launching. I am sure i am making a stupid mistake somewhere.
Help is that, regards
http://render.otoy.com/manuals/Cinema4D/?page_id=651
diegulis
TBA3D_70 wrote:The 0.81 version is crashing C4D R15 on mac OS X ML after make a new C4D-Material and clicking on "Texture tab button" (-> to load a shader, etc...).
-> This (click) is crashed C4D !
So I go back to one of the older/more stable versions :(
Hope you can fix this soon !
Same issue here with R15, :( on Windows 7.
But we are not supporting R15. To work or not is real chance. Sdk is completely changed and transition can be hazardous now. i cannot debug on R15 at the moment
krzychuc4d
Hi Aoktar,
quick question
How can I setup Deep Channel > Material Id to render in Picture Viewer ?
Currently in render settings I got selected Kernel > Info Kernel
after that Cinema renders Geometric normals not Material ID
thanks,
http://www.3structures.com
https://www.facebook.com/3structures
Ryzen 7 2700X / 32GB RAM / RTX 4070 @Win10 64Bit
dinf
Had a minor issue with 081 in R14 with huge file - without geometry update . After working a while, the cinema editor view stopped showing anything. Not reproducable. Changed back to 080 for a while to get this part of work ready.
aoktar wrote:But we are not supporting R15. To work or not is real chance. Sdk is completely changed and transition can be hazardous now. i cannot debug on R15 at the moment
Knowing that, therefore it is working really good in R15 :)
| Win 11 | 64 GB RAM | AMD 5900X | RTX 3090 24 GB | C4D R21 | C4D-Octane v2026.1 |
krzychuc4d wrote:Hi Aoktar,
quick question
thanks,
material-color.rar
material color pass
(150.78 KiB) Downloaded 320 times
Rudi
aoktar wrote:
Rudi wrote:Another Crash.
Load the Scene (c4d) make click on Picture Viewer. C4D crash.
can you try without any plugin and remove videopost tags like global illumination, hair render, etc...
I remove all Plugin and i remove all videopost.
This uploaded Scene still crasht C4D. :cry:
dinf
@Rudi
Read again my answer to your post.
Lies nochmal meine Antwort auf Deinen Beitrag.
