Beta 0.72 / 0.79 (SDK 1.20) - Obsolete
cfrank78 wrote:Hi Ahmet!
I am rendering now a seuqenze with 650 frames with bloom and glare effect. Randomly i get frames like this. This is very weird! Also using bloom / glare and using object id tag makes render manger crash like we had it with 0.72b. I mean the hung up problem! If you need further information skype me!
Kind regard Chris!
hi chris,
i have got some of this frames with errors in glare also with standalone, so i don't think that is plugin related :roll:
the glare-bloom is extremely sensible, maybe some little hole in the surrounding geometry or a white pixel in the hdri are causing this :roll:
ciao beppe
dinf
cfrank78 wrote:Here is the Vid!
Hope its clear!
Kind regards Chris!
Hey Chris, that was very nice, thank you :)
See PN
D.
| Win 11 | 64 GB RAM | AMD 5900X | RTX 3090 24 GB | C4D R21 | C4D-Octane v2026.1 |
cfrank78
hi chris,
ciao beppe
Hey beppe. Thank you! Good to know, so Ahmet can point on the SDK developers this problem :-). Strange. Really strange. Used this HDRI very often in combination with bloom/glare and never had this problem. geometry seems watertight too. Strange. But at least no big deal. Simpyl re redered the frames and after a quick rerender they loooked fine.
Thanks again and have a nice day everybody!
Kind regards Chris!
indexofrefraction
Hope its clear!
Kind regards Chris!
See PN
D.
nice video, but i cant get this working here on mac.
it just locks the resolution of the live viewer window.
it is not taking the resolution/proportion of the render setting
if it's possible somehow it is too hidden / voodoo like.
i vote for a menu in the live viewer to set resolution and/or proportion.
Last edited by indexofrefraction on Fri Sep 06, 2013 10:06 am, edited 1 time in total.
Mac Pro (2012) 2x6 Core | 24GB | 1 x Geforce GTX580/3GB
dinf
indexofrefraction wrote:
Hope its clear!
Kind regards Chris!
See PN
D.
there should be a menu in the live viewer to set a resolution / proportion.
I think there will be an update in short future. Don't know if this will be for Mac also but it includes direct work as it should on PC.
Thanks for that also @Ahmet.
mattfrodsham
Hope its clear!
Kind regards Chris!
See PN
D.
I would love that, plus one!
Windows 8.1 / 4xGTX980 / C4D R18
Silverwing
Hi Ahmet,
thanks for your continuous hard work.
I really appreciate the quick memory leak fix and the better update algorithm!
I however unfortunately encountered a problem with the octane plugin.
I was working on a scene not related to octane with a lot of instanced particles and clones.
Once in a while C4D crashed. I noticed that it was the same crash behaviour then when I was running octane: C4D just froze with no message no backup file and I had to kill the process in the Task-Manager.
Then I decided to remove the Octane Plugin out of the C4D Plugins folder. And voila. No more crashes.
So I guess it had something to do with Octane.
I got crashes mostly when I turned on / off big junks of clones via the mograph Cloner Object.
It almost seems like that the plug is active even if you haven´t activated it!
Would appreciate it if you´d have a look at it!
p.s.
I hope the camera motion blur is still on your to do ist. I´m eagerly waiting for it!
Thanks and keep it up!
Raphael Rau
WIN 10 PRO 64 | ASUS X99-E WS | 3 X GTX 1080Ti | i7 5960X 8X 3,33GHz | 64GB RAM
Silverwing wrote:Hi Ahmet,
p.s.
Raphael Rau
version?
Silverwing
C4D Version:
C4D R14.042
Octane Version:
0.79
Unfortunately I do not have a Bug Report because C4D just freezes without Error!
Thanks for your quick response!
EricDesign
i have question for this plug-in development do you have work for the R15 version of c4d...
thx.
i5 7400 / 2 x GTX980Ti / 32gig ram
http://ericdesign.info
