Problemsignatur:
Problemereignisname: APPCRASH
Anwendungsname: CINEMA 4D 64 Bit.exe
Anwendungsversion: 14.0.4.2
Anwendungszeitstempel: 5187924f
Fehlermodulname: c4dOctane.cdl64
Fehlermodulversion: 0.0.0.0
Fehlermodulzeitstempel: 522225e4
Ausnahmecode: 80000003
Ausnahmeoffset: 000000000012ffd8
Betriebsystemversion: 6.1.7601.2.1.0.256.1
Gebietsschema-ID: 1031
Zusatzinformation 1: 0088
Zusatzinformation 2: 008837ec8acd98b124132ce7ab47301c
Zusatzinformation 3: 947d
Zusatzinformation 4: 947d1a77082ba89620281d94ffd1bdde
Error C4D 14 Render and Program broken
check/disable some plugins or copy libs64 files to c4d main folder
If I move the files from the folder CINEMA 4D R14\plugins\c4doctane\Libs64\ to CINEMA 4D R14\, the Octanerenderer starts no more or does not go at all.
But with copy you think certainly that in both lists these files should lie, or?
These 4 must be there therefore twice.
nvapi64.dll, octane.dat, octane.dll, vcomp100.dll
I hope, you understand.
Supplement:
If 4 files also lie in the C4D list, goes of the octanes Renderer no more: (
Supplement:
Microsoft Visual C++ Debug Library
Debug Error!
Program: C:\Program Files\MAXON\CINEMA 4D R14\CINEMA 4D 64 Bit.exe
Module: ...m Files\MAXON\CINEMA 4D R14\plugins\c4doctane\c4dOctane.cdl64
File:
Run-Time Check Failure #3 - The variable 'lumColor' is being used without being initialized.
(Press Retry to debug the application)
Abbrechen Wiederholen Ignorieren
Debug Error!
File:
can you put your scene there?
c4dOctane.cdl, c4dOctane.cdl64
No matter whether these both files twice exist. Once in the Plugin list and once in the C4D Root list or only in the Plugin list, the octanes Renderer falls, as soon as I on ' use Light Color ' click in the octane Light day.
Live View with the octane Renderer is open. If he is not in, one can click on ' use Light Color ' and nothing falls.
Anbei die c4D Datei.
- Licht1.rar
- Die Datei
- (235.08 KiB) Downloaded 209 times
yes, fixed this little bug. Will be in next update
