OcDS PROBLEMS WITH THE INSTALLATION - read & post here...
Moderator: BK
t_3
vortex3d wrote:HELP!
you'll get a pm - shortly...
„The obvious is that which is never seen until someone expresses it simply ‟
Spectralis
Hi, I'm having problems again with OctaneRender DAZ plugin. This occurred after rendering quite a long animation a day ago. Today I opened DAZ which then crashed. I opened it again and got this error message with the OR Main page faded out:
"Could not access the Settings file:
C:\Users\Ray\AppData\Roaming\DAZ 3D\ OctaneRender_settings.osczdb"
The settings file is in the DAZ 3D folder and is 204kb. Somehow the OR settings file is getting corrupted. I don't know why this has happened because the animation rendered perfectly. I'm not sure how to fix this?
SOLVED!
When DAZ crashed it didn't close properly so when I opened it a second time OctaneRender registered two copies were open and wouldn't work. When I opened the task manager I realised this. Now OR is working again. Phew!
ASUS Maximus VI Extreme, i7 3770k, 32GB RAM, 4 x GTX760 4GB, Win 8.1 x64.
linvanchene
edited and removed by user
Zwavelaar
Well, here is another noob with installation problems ;) The installation of the stand alone software went fine. No problems there. But with the plugin it's another story. You have to unpack the folder and choose the directory. So I chose ProgramFiles/Daz Studio.../Plugins. So it creates several subfolders: OC1.11 and DS4.5.0.014(?) In the last folder there are several subfolders and one of them is called ACM. In this folder there is OctaneACM. First I couldn't open it, because several files were missing. I had to copy them from the main Daz Studio directory (several Qt files). After that I tried to open the ACM file, but the start or activation screen poppes up for only a second and then disappears. I installed it several times with the same result.
So I'm pretty desperate right now. I'm not a computerexpert at all, so my bag with magic tricks is already empty. Can anyone please help me? I want to play with my render :D
O yeah, I'm running on Windows 7 with a GTX 660.
t_3
Zwavelaar wrote:So I'm pretty desperate right now. I'm not a computerexpert at all, so my bag with magic tricks is already empty. Can anyone please help me? I want to play with my render :D
hi - i'll get back to you asap via pm...
Zwavelaar
Latest update of my problem. Everything is working now! I just opened the .exe file for the plugin as 'Administrator'. Just like someone suggested in an earlier post. But after that I had to replace the settingsfile in the Appdata folder.
Well, I hope I can from now on render happily ever after...fingers crossed. ;)
wlebrun
I can get into the OcDS window and it shows it is activated. But when I try to open a saved scene after the update I get the activating OcDS window that just doesn't go anywhere. Photo below.
Can someone help me figure this out?
Version 3 of Poser 3.3.4.77/ Daz 3.3.4.25/ 3DS Max 3.03.4 - 4.20 octane plugins
X79 Sabertooth - i7-3930K 48GB RAM
MSI 1070 8GB Liquid Cooled
Windows 10 Pro x64 (ver. 1607)
wlebrun
Im sure there has been an Update since March but I installed the latest. Maybe there is some mix up?
wlebrun
Got it Reinstalled again as administration as posted above. Whew :lol:
Jools
Hi all,
I switched to a Samsung 850 EVO 250 GB SSD today. DS installed fine on the SSD, as did the Octane Render standalone. The DS plug-in installer however will not work, not even in administrator mode. It doesn't find the DS folder and it doesn't unpack to folder. So I tried unpacking to my old HD, guessing the SSD was the problem, and that worked fine. So I now have an unpacked folder with the plugin files. Where to go from here?
Thanks in advance.
Return to “DAZ Studio”
