Octane crash C4d on launch
paviaden
As i recently did a full reinstall of my machine, i did install the newest verion of the plugin using the installer, selected the c4d main directory and my version (r14) - however, i simply cant start up C4D anymore after this install, - removing the plugin make me able to use my C4D - but i cant get the newest version of the plugin to work at all.
paviaden wrote:As i recently did a full reinstall of my machine, i did install the newest verion of the plugin using the installer, selected the c4d main directory and my version (r14) - however, i simply cant start up C4D anymore after this install, - removing the plugin make me able to use my C4D - but i cant get the newest version of the plugin to work at all.
Hi paviaden,
this is classic question. Copy Libs64 files to main folder or check your other plugins a few which causes this (TurbulenceFD, etc...)
paviaden
I copied the files from libs64 into the main folder and - it works - Thanks for the speedy help Aoktar <3
paviaden wrote:I copied the files from libs64 into the main folder and - it works - Thanks for the speedy help Aoktar <3
good lucks ;)
