Bedroom
mat985
Hi Octaners!
Here is my very first interior scene test with octane and my new GTX Titan. Hope you will like it!
C&C are very welcome.
Direct light (4), rendertime : 1h, little post-prod in photoshop.
Cheers
User avatar (Default)
merid888
1 hour ?? is a lot time,you should rendering in minutes with that titan, i have 1gtx690 and is so fast the render
but away, nice render i like it, to be your first time is a perfect image !!
glimpse
Nice! & I love that chair - have made model of it not so long ago too =)
as said, maybe rendertime is a bit too long,
but I have no doubt You could simply stop it earlier =)
cheers
Zargon
beautiful work!
mat985
Here is an update with a new bed...
Curcis
Bonjour Mathieu, tu es sous la version Standalon ou celle de max?
J'ai également une titan, et le rendu ne devrait pas dépasse 15mn...
Quelle est la taille de ton image finale?
A+ :D
mat985
Salut Curcis,
Je suis sur la standalone et travaille avec c4d.
La taille finale de mon image est 1280x1024.
Je l'ai traitée en mode DL diffuse avec 16000 maxsamples.
Si tu as des astuces pour diminuer le temps de rendu, je suis preneur!
A+
Silverwing
Very well done.
Very good lighting and Matertials!
Keep up the good work!
Cheers,
Silverwing
WIN 11 PRO 64 | ASUS X299 SAGE | 1X RTX 4090 3X RTX 3090 | i7 10980XE | 128GB RAM
mat985
Thanks guys!
Does somebody know how can I change my signature???
xxdanbrowne
I liked the first bed better. Although the lighting and texturing is spot on the folds look too sharp on the second bed. Unless the duvet/eiderdown is made of very stiff material. If it is supposed to be a regular duvet/eiderdown the folds need to be softer.
