Beta 0.72 / 0.79 (SDK 1.20) - Obsolete
NVN
aoktar....i have the next problem.
I send u a pm
Silverwing
I like to share a video to show incoming new editor for node based editing for materials. This is a little preview for new Material Node Editor. This is under highly WIP. Please ignore some problems, this is not final quality product.
That looks fantastic. Very well done. I´m impressed!
Keep up the good work. Cant wait to play with this!
Cheers,
Raphael
WIN 11 PRO 64 | ASUS X299 SAGE | 1X RTX 4090 3X RTX 3090 | i7 10980XE | 128GB RAM
sphericall
Win 7 64 bit | 2 x GeForce GTX 660 | Intel Core i7-930 CPU 2,8 GHz | 8GB | Cinema 4d r15 Visualize (no Mograph, no Hair)| OCTANE benchmark scene 2,06 Ms/sec
pokeit
Do you have Turbulence FD?
In that case uninstall TFD or (this workaround possibly unstable) copy Octane.dat and Octane.dll into the Cinema 4d root directory.
I believe a workaround is being worked on...
Cheers!
Poke
2xI7 3930K 3.2ghz/32gig/Win10ultsp1 1xI7 6950X @4.0ghz 2x Titans 1x 780ti 3x 980ti
C4DR15 OctaneC4D 3.03.3 SDK 3.03.3 Mobo: AsusP9X79 Pro
sphericall
pokeit wrote:Do you have Turbulence FD?
Poke
Problem solved. Ihave different Cinema home dir so the installer installed plugin into default plugins location, while older Octane plugin version still existed in the homedir plugins directory. After deleting one of them, everything runs smoothly.
pokeit
Jolly good!
areafilm
I've Octane for 3DSMax and for C4D.. I must to say that in 3DSmax the engine is very stable.. not the same for C4D versione..for now.. but you are doing a great work ;)
areafilm wrote:I've Octane for 3DSMax and for C4D.. I must to say that in 3DSmax the engine is very stable.. not the same for C4D versione..for now.. but you are doing a great work ;)
which version? still do you have any crash?
DennisK4
The Material Node Editor looks fantastic aoktar. Keep up the great work.
Win 7 x64 | 2 x GTX580 3GB | i7-2600K 3.4GHz | 16GB | Cinema 4D R14 | Nvidia 320.18
dinf
Hi again,
Cinema crashes while rendering an animation because of RAM overflow. Not the VRAM! This is about 1GB while rendering. RAM usage is exceeding limit while rendering frame by frame until Cinema crashes. In the picture you see the line between the renderings, going up.
The scene contains static objects and keyframe animated and a huge count of baked dynamically animated objects. I first tried "Update Materials Every Frame" and "Update Meshes Every Frame" and gave all animated objects the Object Tag with different numbers. So it is starting to render fast every frame, but the main RAM flls up after a bunch of frames and is shutting down Cinema. After a while, some render instance objects weren't rendered anymore.
So I tried the "Full update Scene" option. Starting to render each frame now takes a minute longer due to the complete scene export, though RAM is also exceeded like seen in the above picture. I'm wondering about that since exporting every frame should empty more RAM in between the exports (I think the down pikes), right? But it does only a bit and fills up RAM every frame a bit more until it crashes after some frames.
I can restart the rendering at this point for the next 20 to 40 frames. And so on. This means, RAM could be cleared up more between exporting and rendering, otherwise it would be exceeded immideately after restarting Cinema. Is there another way to control the RAM usage?
| Win 11 | 64 GB RAM | AMD 5900X | RTX 3090 24 GB | C4D R21 | C4D-Octane v2026.1 |
