Preview of OctaneRender for Revit
jinngonqui
Status Report..... (Fri May 17, 2013 2:15 pm)
Wow, this is great! My trigger finger is getting itchy too ... new updates, please :D
The Revit plugin now has geometry proxies and instancing implemented. I'm just finishing up the manual now. So not far off a release.
Support for ArchiVision RPC prop rendering is unlikely to be in the initial release but such be available shortly after.
B_M_A
any news?
looks so promising!!!
designe
How does the workflow integrate with low poly tree meshes and a randomizer generator such as Crowd?
http://revitaddons.blogspot.com/2013/04 ... r-add.html
any update on the Revit plug-in release?
Hi
To answer the question on the randomizer.....you can load any OBJ mesh into the Octane scene in place of a Revit object. For example, you can assign a Revit RPC person with an OBJ person mesh. For Revit elements which are assigned OBJ proxies like this, you can load a transform CSV file (as you would with Octane Standalone) to "instance" that OBJ mesh many times. If the "randomizer" plugin can write the instance transform to CSV, you could load that into the plugin.
When you load OBJ proxies, you can also edit that Octane materials for those proxies, so the whole system is very easy to use.
Jorgensen
Hi Paul
I'm not very used to do detailed illustrations in Revit (I use Lumion for that), therefore - can you use the OBJ mesh loader to add high quality trees in Revit?
Any news about the status of the plugin?
Jorgensen
Yes.
It's finished and due for release.
The plugin has been released. Pls see http://render.otoy.com/forum/viewtopic.php?f=7&t=34039 for details.
