Pathtracing and Grainy
Forums: Pathtracing and Grainy
Postby morphious2013 » Sat Jul 20, 2013 1:22 am
morphious2013 Sat Jul 20, 2013 1:22 am
After 5 minutes of rendering, the image is still grainy.
I have searched through the forum, and tried all the recommendations. I know Direct light will cure it, but I need to render in Pathtracing as it has a more realistic look. Here is what I have tried.
> Increase Caustic blur to 1
> Hotpixel to 0
> Increased IBL power
> Lowered Maxdepth to 4
> Lowered Maxsamples to 8000
Are there any other tweeks I can make to get rid of grainyness?
Thanks.
Randall.
Gateway i5 3.2ghz, 16g RAM, GTX 690 4GB VRAM, Windows 10 64bit, Poser Pro 11, DAZ Studio Pro 4.9, Daz Octane Plugin V2, Poser Octane Plugin V2
morphious2013
Re: Pathtracing and Grainy
Postby glimpse » Sat Jul 20, 2013 6:09 am
glimpse Sat Jul 20, 2013 6:09 am
tey changing hdr - some of them do produce a bit more noise than others..
tomGlimps | [email protected] | 32GB | TitanBlack
Available for Freelance, Coaching & Mentoring
glimpse
Postby face_off » Sat Jul 20, 2013 6:17 am
face_off Sat Jul 20, 2013 6:17 am
There are some other ideas at http://render.otoy.com/manuals/Poser/?page_id=210. The biggest culprit seems to be small emitters, or emitters with too many polys. If you post a sample of your scene, it might give a better indication of the graininess cause.
Postby gabrielefx » Sat Jul 20, 2013 8:44 am
gabrielefx Sat Jul 20, 2013 8:44 am
it depends by thousands of factors:
closed spaces without apertures
tiny light with many polygons + large lights
use massive of ies emitters
not illuminated areas, too few bounces or too many
too many glossy materials
not well balanced samples for each light/emitter
slow gpus
gabrielefx
Postby morphious2013 » Sat Jul 20, 2013 6:26 pm
morphious2013 Sat Jul 20, 2013 6:26 pm
I am only using IBL light. No emitters. No glossy surfaces. I can't post an image as it is porn and against forum rules. I will look at other thread you posted. If any other ideas come to mind, please post. Thanks.
Randall.
morphious2013
Postby face_off » Sat Jul 20, 2013 10:31 pm
face_off Sat Jul 20, 2013 10:31 pm
Without seeing a sample it is very hard to determine what is causing the graininess. Is the light illuminating the scene coming through glass before hitting the objects being lit? Is the whole render grainy, or just one part?
Postby morphious2013 » Sun Jul 21, 2013 3:27 pm
morphious2013 Sun Jul 21, 2013 3:27 pm
No, nothing blocking the scene, no light passing through glass or anything. Whole picture is grainy. Just seems to take 6 minutes to just get past the grainy look. Seems a bit long. Wonder if it is because I am use hdr files for IBL, instead of jpg for IBL? Do you recommend one or the other? JPG seems to be a bit better with the grainy look, but not much. I would think with my card, the grainy look would be gone sooner.
morphious2013
Postby mbetke » Sun Jul 21, 2013 5:24 pm
mbetke Sun Jul 21, 2013 5:24 pm
HDR images are a bit tricky to set up.
I have to lower the Gamma from 2.2 to 1.5 or even lower of the Environment material (I use 3dmax but there will be some setting in your app maybe too).
Also lowering the ISO can help if your image gets flooded by high orange loooking grain.
Sent me an image or the HDR too so I can take a look. I don't care about porn or not. :lol:
Pure3D Visualisierungen - Germany
Sys: Intel X5690, 128GB RAM, 2x Titan RTX, Windows 10 Pro x64, 3ds Max 2019
mbetke
Return to Poser
Tue Jul 14, 2020 7:45 am [ UTC ]
