seems that the new .72 Beta is a little step backwards.
Still have these washed out colors and like in earlier Versions
Octane looses textures.
Haven't been there some improvements in previous version .69 ?
MIke
beta 72 loose textures again and still washed out colors
Do you mean the final render is much brighter/less contrasty than the live viewer? If so that's Linear Workflow. Render your final images in 16bit or convert your project to linear workflow.
I also get some textures that need constant relinking, less than before though. I find it better if you select 'no' when cinema asks you if you want to copy your texture images into the projects' path..
Hope this helps
Cheers!
Poke
Hope this helps
Cheers!
Poke
2xI7 3930K 3.2ghz/32gig/Win10ultsp1 1xI7 6950X @4.0ghz 2x Titans 1x 780ti 3x 980ti
C4DR15 OctaneC4D 3.03.3 SDK 3.03.3 Mobo: AsusP9X79 Pro
Hi Poke,
I already discussed that with aoktar.
As soon as I have set texture paths in C4D Prefs,
Cinema won't aks me to make a copy.
Would be nice, if Octane could directly use the
texturepaths from C4D Prefs.
In .69 this was fixed I thought.
Mike
Mike
Hi Mike,
I found if I set up the C4D paths it took ages (minutes, in fact it may have crashed never left it long enough to find out) for Octane to export the scene so I gave up
this is seems like a wrong settings. Can you check again?
For texture paths: if c4d paths was accesible, we will be using thats.
