Hi BorisGoreta,BorisGoreta wrote:Thanks for your report. Problem is that even if I set the global CUDA options to use only 1 GPU I still get OpenGL 1.1 which are only some basic OpenGL functions. When you boot into windows please check your OpenGL version.
Do you have regular nvidia drivers installed or some CUDA special drivers ?
CUDA swithces work for CUDA but have no effect on OpenGL.
I don't understand how can your system have good OpenGL with so many GPUs.
here is a screenshot of the OpenGL Extension Viewer after startup with all my gpus "online".
The first GTX580 is the one in my PC, all others are in the turbobox. As you see it shows Open GL Version 4.3.
I have only normal NVIDIA driver installed, no CUDA SDK or similar.
The program seems only to detect the first GTX580... so only this one might be in use for Open GL?
What does your extension viewer show up when all 6 cards are active? How about the render test?
Here is the render test of mine... comped two screenshots together to show it only used the GTX580... at about 30% load, getting about 1200 fps average with Open GL 3.0 - 4.2.
