The Wishing Well
- Elvissuperstar007
- Contact:
ID material
- gabrielefx
[20] noiseless photometric light distribution
[21] target lights with visible ies gizmo
[22] vraysun translation
[23] vray ies translation
[24] texture decal
[25] better procedural textures
[26] physical corrected mixing of materials
[27] wire edge shader that works with materials
[28] support for vray or proprietary proxies
[29] material override
[30] Max render channel output support
[31] 32 bit tonemapped output
[32] alpha on specular materials
[33] realtime lens flare with presets
[34] sky presets
[24] texture decal
[34] sky presets
[33] UNDO COMMAND (so obvious it almost feels like a joke).
I think i´ve seen some posts in the forum where people say they don´t need the undo. Sure, it works without. But some times you just want to play around with the sliders, and it would be a mush more comfortable process if you knew you could just hit ctrl+z a bunch of times. And in the cases you actually move something by misstake, or delete something...
I wonder what the reason for the choice of not having it is. Is there a good argument from the developers? It can´t be a technical issue, right?
[34] (Random) displacement/rotation/scaling of the same image texture connected to a scatter node and instances.
[35] Algebraic transforms, i.e., multiplication (also by negative numbers), addition, etc.
[37] negative scaling in any of x,y,z directions
Hi all,
>> Alembic static / anim ?
>> Timeline and key for animating data
>> obj reader with obj animation option
>> Better transform (object based rotation, not rotation from center) and scatter
>> 3D volume datas for smokes and clouds, to voxel them and put volumetric shader (standard, not from nowhere
>> A solution to bypass the gpu memory limit, like buckets / shared system memory as option ( I know, less fast but better for production ) ?
>> a real matte material, with direct transfert color, reflection, refraction and co
>> 3d support other than anaglyth, polarized, dynamic and option to output the separate two pictures
I know it's a whish list
Matt
Matt
- Rikk The Gaijin
[38] on-screen axis manipulators for move, rotation and scale (like any other 3D application)
[39] object-based rotation pivot
(40) combined HDR and daylight lighting system
