Octane exporter for C4D version 0.12b (current)
Forums: Octane exporter for C4D version 0.12b (current)
Moderator: aoktar
Re: Octane exporter for C4D version 0.12b (current)
Postby ello » Mon Jul 15, 2013 11:12 am
ello Mon Jul 15, 2013 11:12 am
hey, after some time and triggered by the update i wanted to try the exporter and octane. but i get an error message telling me "could not launch octane"
the OctaneRender Path is set correctly, and project path and such is there, too.
hope someone can help me with this.
cheers,
Ello
win7,i5 760 6gb,gf 460 1gb
my cinema4d plugin collection for creating complex random or ordered structures and more: http://plugello.earthcontrol.de
ello
Postby Silverwing » Wed Jul 17, 2013 1:12 pm
Silverwing Wed Jul 17, 2013 1:12 pm
The only help I can give you is that it must be a thing on your system.
I thought it´s maybe because they changed something in Octane Standalone. But I just tried it to see and it worked as it always did.
The only thing I can say is to make sure you set the OctaneRender Path correctly (But you already wrote you did) :-(
Cheers,
Silverwing
WIN 10 PRO 64 | ASUS X99-E WS | 3 X GTX 1080Ti | i7 5960X 8X 3,33GHz | 64GB RAM
Silverwing
Postby abstrax » Wed Jul 17, 2013 9:09 pm
abstrax Wed Jul 17, 2013 9:09 pm
ello wrote:hey, after some time and triggered by the update i wanted to try the exporter and octane. but i get an error message telling me "could not launch octane"
cheers,
Ello
What does the console log window say?
abstrax
Postby smoke2000 » Mon Aug 05, 2013 6:28 pm
smoke2000 Mon Aug 05, 2013 6:28 pm
Just would like to say "Thank you" for this exporter plugin. I needed a simple method to be able to import zbrush models with subtools into octane and couldn't find a decent way to get different materials for every subtool in octane. By going through cinema4d with your exporter, it all gets taken care of and I didn't have to buy the integrated plugin just to use cinema4d as a gateway ;)
smoke2000
Postby Hris » Fri Oct 04, 2013 10:56 pm
Hris Fri Oct 04, 2013 10:56 pm
Thank You very,very much for this exporter:)
I'm still using Cinema 4D R10.1 version. The biggest question for me is:
-)Is exporter for C4D R10.1 in development or rather 0.12b version is the last released for old C4D versions...
Thank You for you hardwork for community.
Krzysztof Czerwinski
Win 7 64 bit, i7-970 OC to 3.9 Ghz, GTX580 3GB + GTX560 Ti 2GB, 18 GB Ram
Hris
Postby Hris » Fri Nov 22, 2013 1:38 pm
Hris Fri Nov 22, 2013 1:38 pm
OK, now after 1,5 month of silence in this thread in know that plugin for old C4D (R10) is dead....just great...
Hris
Postby abstrax » Fri Nov 22, 2013 8:46 pm
abstrax Fri Nov 22, 2013 8:46 pm
Hris wrote:OK, now after 1,5 month of silence in this thread in know that plugin for old C4D (R10) is dead....just great...
Sorry, didn't see your post. There isn't much more that can be added to the exporter functionality, since the way how data can be exported to Octane is fairly limited. I have a few minor improvements done, but nothing major and I got the instancing export done only half way. Since Ahmet's plugin integrates Octane very well into C4D I thought it's not worth putting any work into it anymore.
What exactly do you need?
abstrax
Postby Hris » Mon Nov 25, 2013 1:20 pm
Hris Mon Nov 25, 2013 1:20 pm
Wow! Thank you for your response. I know that this exporter is old and almost all people around world are using newer version of Cinema 4D (R12+). But i don't have any chance to use newer version.
What about plugin - is chance to better connection between C4D materials and Octane shaders?
Last time i made project of some synthesizer (some virtual model instrument), i made materials for this model in C4D (diffuse, reflection, transparency, speculars) - without bitmaps.
After export to Octane Standalone (OBJ all materials was totally different:( All speculars, reflections, transparency parameters i had to set again from scratch.
I don't know what possibilities are able to covert C4D shaders to Octane shaders:( maybe it's already done but my exports (obj) are wrong.
Kind regards and respect for your hard work for community
Krzysztof Czerwiński
Hris
Postby CinemaGFX » Tue Dec 24, 2013 3:20 am
CinemaGFX Tue Dec 24, 2013 3:20 am
I got the error "Could not launch Octane."
Fix?
CinemaGFX
Postby Kassad » Mon Jan 27, 2014 9:00 am
Kassad Mon Jan 27, 2014 9:00 am
I'm using Octane render 1.2 with Octane exporter for C4D (R12) for a while on a IMac under Maverick.
After trying the beta versions of Octane, (1.26, 1.27) I came back to version 1.20 (cannot save my old material with version 1.26, 1.27)
Now, I cannot export correctly my scenes from C4D to Octane.
It looks that it is a camera problem.
I remove all octane programs and reinstall version 1.2 and plugin 0.12b with the same problems.
Is it a way to restart to a fresh installation of Octane and the plugin, or what parameter have I to change to go back to normal?
Thank you.
B->
Kassad
PreviousNext
Return to Maxon Cinema 4D
Users browsing this forum: No registered users and 5 guests
Sun Jun 16, 2024 12:10 am [ UTC ]
