Beta 0.72 / 0.79 (SDK 1.20) - Obsolete
ron908
Ok, at first start, Cinema immediately crashes, because the installer did not copy the libs into the C4D root folder.
ron908 wrote:Ok, at first start, Cinema immediately crashes, because the installer did not copy the libs into the C4D root folder.
Hey ron,
Installer will not put files to main folder. It's a workaround when you have a conflicting with other plugins. Crashes points that octane plugin cannot found octane system files.
EDIT:
Reuploaded againg. Problems was missing assets. Also take care with install options.
ron908
Hi aoktar,
thanks for taking care of it. Any chance we can get a manual install / zipped version as well?
ron908 wrote:Hi aoktar,
i want to give up the zipped distributions. We have to put again again same files for different versions.
Seperately If you choice correct version, installer must be extract related files. I know giving path is confusing. Be sure you have giving exact path Cinema 4D, not plugin path. Similar to "c:\program files\Cinema4Dr13"
pokeit
Can anyone cast any light on why I would get some frames in a sequence rendering in 1' 52" and another frame taking 17' 49" in the same sequence???
Very odd and overall making my render much slower :(
2xI7 3930K 3.2ghz/32gig/Win10ultsp1 1xI7 6950X @4.0ghz 2x Titans 1x 780ti 3x 980ti
C4DR15 OctaneC4D 3.03.3 SDK 3.03.3 Mobo: AsusP9X79 Pro
pokeit wrote:Can anyone cast any light on why I would get some frames in a sequence rendering in 1' 52" and another frame taking 17' 49" in the same sequence???
can you show me screenshots on picture viewer images? it's weird and shows still has a animation render problem
pokeit
I can- please see attached. it ssems to be almost cyclical with a high render time frame every 11 frames... and similar levels of fluctuation between them... :(
pokeit wrote:I can- please see attached. it ssems to be almost cyclical with a high render time frame every 11 frames... and similar levels of fluctuation between them... :(
do you have wrong frames on sequence as double or similar to previous? What is your gpu settings on gpu section?
pokeit
Another grab this time showing octanes data at the bottom...
pokeit: do you use your two gpu or one for rendering? I have noticed gpu/s are using nearly all memory. Can you try to lower some texture sizes and try only one gpu which is not used by system(not connected to monitor).
