But I loaded the OBJ from the geometries folder into Modo and just saved it again. That fixed the problem
For skin or non-skin materials?How do I force the scene to use glossy specular 0.05 ? It seems every time an image is connected to the specular pin it's set at 1.0.
If there is a specular map attached in the Poser material, then that material will convert to an Octane glossy, with that specular map attached to the "specular" pin.For non-skin materials. I was trying out different hair on a figure, but about 80% had a specular map attached and octane set it to 1.0. Was messing around in the config file but that didn't help me as it use to do.
