Hi all,
I wonder if anyone could tell me what's going on here.
The attached two images are the same scene.
Screen grab of the render window at 99%
And
The final result of the 'F9' render....
Using the PMC Kernel the final render always gets majorly blown out, and I can't figure out why. I've detached the post processing node, so it can't be that. It's very confusing.
Anyone have any ideas?
TheMightySpud
Weird PMC Kernel problem.
it seems to bee a gamma problem, can you disable any gamma settings if there are any and try again ?
Core i7 860, ZOTAC GTX 580 - 3GB, 2 x GTX TITAN, 32Gb RAM
- TheMightySpud
Thanks for the replies.
I've double checked all the settings and there's no LW gamma correction enabled, all the color space options are set to linear etc.
All very weird :-/
TheMightySpud
All very weird :-/
TheMightySpud
Also if you can send to me the scene (or a scene with this problem) could be great to test it here.
You can use my email if you want: [email protected]
- TheMightySpud
Thanks for the replies. I've tried with the pathtracing Kernel but the problem persists, so I'm guessing I've missed something somewhere in regards to the gamma settings.
I've emailed the scene etc. over.
TheMightySpud
TheMightySpud
Ok ... I can see this issue here.
Problem is that you have a pure linear settings in the imager node (gamma = 1.0 and response = linear). With this settings plugin read the HDRI Octane frame buffer without clamp the image range and without tone mapping (that is, you get a full not clamped HDRI image, not a tone mapped one).
The preview functions which allow plugins get the preview image while rendering are always clamped and tone mapped and never get the full floating HDRI information.
This is why you can see the diference between preview and final rendered image.
You can easy fix this issue (if you don't need the full not clamped HDRI image) simple setting the gamma in the imager node to somthing like 1.0001 ... this force the plugin to get the final image using the clamped HDRI buffer, and preview and final image are going to be the same.
Perhaps I should add a switch to enable the full HDRI not clamped image only if user need this kind of output image to avoid this issue with preview. Usually all Octane users output the image with some kind of tone mapping (some film response or gamma correction), this is why it is not easy to have this problem.
- TheMightySpud
Aaaah, interesting.
Thanks for that, and the really quick reply, I shall take a look
TheMightySpud
TheMightySpud
