Hello,
We're trying to get octane nodes to work with netrender. It says empty account/password, but when I click the plugin from within the netrender client, nothing happens. how/where can I enter the account?
::mate::
Octane with Netrender
SEHSUCHT Berlin - 22x GTX 780
there is a file oct.dat for settings in c4d prefs folder. If you put oct.dat for same machine in netrender pref folder, then must work
great seems to work! is there a way to access settings such as which GPUs to use?
also there seems to be problems wit path, it throws file not found error for the textures
use octane settings->texture paths for a collected texture pathmate wrote:also there seems to be problems wit path, it throws file not found error for the textures
From inside Netrender I can't access the settings. Do I have to change it in the C4D main program and then copy the oct.dat over?
yesmate wrote:From inside Netrender I can't access the settings. Do I have to change it in the C4D main program and then copy the oct.dat over?
