Testing beta 0.69a -> 0.69b (Update for sdk 1.18)
miroof wrote:0.69x c4d R12 problem with texture as image in cubic mode and the importation from liveDB are not good.
did you check on r13 or 14?
miroof
my friend do not have any problem on this subject on R13
| i7 3930K @4.6Ghz | ASUS RAMPAGE XTREM | 32 Go DDR3/2400 | 2x 660 GTX TI OC |
miroof wrote:my friend do not have any problem on this subject on R13
Ok, i found problem that is related with r12. If you want i can send you private copy
miroof
it s ok, i can wait next upgrade
rik25
For portal
In this version a window with a portal cannot contain glass at this time ?
rik25 wrote:For portal
you sould put portal material and glass material seperate meshes
areafilm
Hi there.. VERSION 0.69B with a use of two lights and a HDRI Environment.. in rendering scene, still in PREPARING SKY MAPS, and don't work more.. Works fine only in preview render :?
areafilm wrote:Hi there.. VERSION 0.69B with a use of two lights and a HDRI Environment.. in rendering scene, still in PREPARING SKY MAPS, and don't work more.. Works fine only in preview render :?
can you share me the scene?
NVN
hi there...
i render my scene right now and i have some Problems.
My render tooks 7-8 Minutes per frame....but he saved all 7-8Min two Pictures with 0 Min Rendertime???
And....i get every time some Errors when i use standard piture viewer from Cinema.
when i took the octane picture preview window it works....normal?
Greets NICK
NVN wrote:hi there...
Greets NICK
what is your version of plugin?
