How to Render animation to AVI or QT or a movie format
- morphious2013
I need to render to a movie format. Octane only does image sequence, is there a work around or will there be a movie export feature in the future? Thanks.
Gateway i5 3.2ghz, 16g RAM, GTX 690 4GB VRAM, Windows 10 64bit, Poser Pro 11, DAZ Studio Pro 4.9, Daz Octane Plugin V2, Poser Octane Plugin V2
just import png into photoshop and export as avi job done
W7 64 bit |I7-3970X | GTX 780 X2(6GB) GTX 780TI X2 | 64 GB DDR3 RAM
Real Skin & real hair for Poser / DAZ Studio OctaneRender/iray - coming soon
- morphious2013
Yes, but I need 60fps. Image sequences negate that, Need to export straight to QT or AVI
I've use VirtualDub (open source) and it works well.
yep photoshop will do 60fps as well just change it on inport
- morphious2013
OK, I;ll give those 2 options a go. Is there a avi, QT or mov export feature being added in the future?
That would be nice, but I'm not sure how all the different movie formats could be covered without using a 3rd party library, which would push up the cost of the plugin significantly. At the moment you can compress the frame into whatever format you like using whatever software you have, which seems like a good workflow. Regardless of the movie format it renders to, you are still most likely going to do some post work on the clip (titles, etc), so it's just as easy to feed the clip editing software png frames as an avi.Is there a avi, QT or mov export feature being added in the future?
