A tip about transparency shadow problems
Zay
Was playing around with the new plugin when I had the known transparency problem when two object are very close to each other. This can happen with hair, pockets on pants, shirts,jackets or when you want to hide some stuff. Normally you can change the Rayepsilon slider to fix this, but this can also create unwanted side effects like bad shadows from low geometry objects.
In this scene I have a shadow problem with the hair line. Many ways to go about that, but I use my favorite fix which is fast and that is to scale the scene. Under Setup I changed the scale from 2.6 to 10. This is just a quick fix I hope you can use if you run into this problem in the future.
Hair line casting a shadow.
Scene scaled to 10 to fix it.
Win 11 Pro | i5 12600K | 32GB ram | 2x GTX 1080Ti + 3080Ti - studio driver 581.57| Modo/Blender/ZBrush/Daz/Poser
bpzen
thanks, dumb question what are you changing the scale of the hair?
Win 7 64bit, Titan 6 Gig and GTX770 4Gig, Intel 3.75GHZ, 24Gig RAM, Poser 2014 patched
Zay
Use the scale setting within the Poser plugin. It scales the entire scene.
Click the Setup button to get to the configuration window.
bpzen
I gave this a try but it really messes up lighting, is there a way to set this and have the lighting in octane scale appropriately or do we need to re do lighting too?
morphious2013
I guess I need stronger glasses. I honestly see no different in pics.
Gateway i5 3.2ghz, 16g RAM, GTX 690 4GB VRAM, Windows 10 64bit, Poser Pro 11, DAZ Studio Pro 4.9, Daz Octane Plugin V2, Poser Octane Plugin V2
Krew
morphious2013 wrote:I guess I need stronger glasses. I honestly see no different in pics.
I couldn't either until I opened both pictures in separate tabs and switched back and forth. In the first picture, look at the thin black line above the left (screen left) eyebrow and just under the widow's peak of the hair. I think those are the shadows talked about. In the second picture those are gone.
Windows 10 64bit | 2 x NVIDIA TITAN XP 12GB | Intel i7-6900K (8 core/16 thread) | 64Gb RAM | GeForce Driver 376.33 | PoserPro Game Dev 2014 SR4, 10.0.5.28925 | Poser Octane Plugin Version: 3.4.4.79 | HDR Light Studio 4.3.20131206.1249, Poser v1.0.3
Zay
As Krew mentioned there's black lines from the hair cap. It's a transparency issue you can run into now and then.
bpzen wrote:I gave this a try but it really messes up lighting, is there a way to set this and have the lighting in octane scale appropriately or do we need to re do lighting too?
Area and IES lights can change as the distance will be longer. HDRI doesn't (not that I have seen). So I would just fix it in photoshop if there's too much work to try and fix it with the scale option. I usually have a higher scale option from the start now when setting up scenes to prevent this from happening in the first place.
In the standalone I also use decameters as default as it helps to fix those things. But not always.
Zay
Here is a better example. Here I have hidden the pockets by setting the pockets opacity to 0. Notice the black shadows. But this problem only happens when 2 geometries are very close to each other.
So if you see things like this you know what to do. Either scale the scene or try to pull the surfaces away from each other. That also goes for the hair. Maybe the morphtool can pull it out so you don't need to adjust the scale. But that properly wouldn't work on the pockets.
Return to “Poser”
