OctaneRender® for 3ds max® v1.18[Test]
Karba
Changes since 1.17
  • Fixed material preview bug.
  • All material properties are shown in track view editor.
  • Fixed black dot on specular material
  • Inverted bump mapping behavior to make it more consistent with other renderers (lighter color means higher elevation). This means that when upgrading you need to check or uncheck the invert input on bump maps.
This version requires video driver 301.42 or higher.
Limitations on old cards
The PMC kernel and the matte material options don't work on old graphics cards (GTX 2xx, compute model < 2.0).
DOWNLOAD
We have 4 separate archives available for download, for Autodesk® 3ds max® 2010, 2011, 2012 and 2013.
Each archive contains the manual and installation text file, and both 32bit and x64 versions of the plugin,
so you only need to download one archive for your 3ds max® version from the following download links:
3ds max® 2010: http://www.refractivesoftware.com/plugi ... _v1.18.zip (50MB ZIP File)
3ds max® 2011: http://www.refractivesoftware.com/plugi ... _v1.18.zip (50MB ZIP File)
3ds max® 2012: http://www.refractivesoftware.com/plugi ... _v1.18.zip (50MB ZIP File)
3ds max® 2013: http://www.refractivesoftware.com/plugi ... _v1.18.zip (50MB ZIP File)
Yours,
The OctaneRender® Team.
Elvissuperstar007
bug
Vanya
Elvissuperstar007 wrote:bug
operating normally :)
Karba, this mazda looks great. Thank you. :)
Core i5 76o @ 2.8o GHz | ZOTAC gtx58o AMP 1536Mb | MSI gtx46o 1o24Mb | Corsair ForceGT SSD12o | Gskill 16Gb RAM 16ooMHz
Elvissuperstar007
3ds max 2014
1,17
Elvissuperstar007
все нормально! .. у меня произошел сбой! работает
it works thanks!
Karba
Elvissuperstar007,
You are my nightmare. :shock:
glimpse
=DDD welcome back, Dear. Thanks for update!
truerender
Same BUG: OctaneViewport updating only when press PAUSE :twisted:
Karba
truerender wrote:Same BUG: OctaneViewport updating only when press PAUSE :twisted:
We are working on it.
Karba
Could you please explain in details what you did to reproduce this bug?
Return to “Autodesk 3Ds Max”
