Scattercity (vertical perspective lines?)
rappet
Hi Guys,
I just played around with the Archicad plugin and scattering and rendered this image in DL 100 spx and downscaled it 50% to 2048x1024 px.
I used same y-coordinate for target as used for camera and used vertical lensshift to set my layout nicely.
I did not expect vertical lines in the perspective.. you can see this best by looking at the buidling on the left side.
Maybe it is due to the fov? I set fov on 70.
Does anyone has an idea why this happens?
greetz,
4090+3089ti & Quad 1080ti
http://www.tapperworks.com
roeland
The camera probably is still slightly pointing down. With a wide angle like this even a small deviation will result in seeing converging vertical lines.
Roeland
rappet
Indeed,
I did not use same y-coordinate for target as used for camera. I thought I did.
Thanx Roeland, for m aking me check.
Return to “Works In Progress”
